SBC Dyno results, where to go from here
rustbucket79
Post by rustbucket79 »
406, Dart Little M, AFR 245's, 12.5:1, 266/271 @.050, 109 lobe separation, .449"/.437" lobe lift, 1.7I/1.6E rockers, 1 3/4 dyno headers, Super victor 4500 port mached and plenum work, Holley 1150 HP. (best numbers but ultimately not the carb that will be used)
I tested with 4 different intake manifolds, 4 different carburetor configurations, with and without a vacuum pump, and different cam timing. This test happens to be with the camshaft 2 degrees retarded. This is an old build (bracket racer) that will ultimately be torn down and freshened before it sees the track in another year. Thoughts are a bit more compression, possibly a different cam, and maybe even a bit more stroke.
The engine is solid but ultimately, is there much on the table here or am I chasing just a few numbers?
Geoff2
Re: SBC Dyno results, where to go from here
Post by Geoff2 »
Where to go from here? With those #s, I'd say the drag strip!
mag2555
Post by mag2555 »
Well your heads are tapped out at 5600 rpm, but where do you actually shift the motor at 7200 to 7400?
It would be nice if that dyno print out also stated how much VE the motor made as I don't know what those heads flow , but it took 320 cfm to produce your 662 coreccted HP.
vortecpro
Post by vortecpro »
Geoff2 wrote: Mon Feb 05, 2018 3:26 am Where to go from here? With those #s, I'd say the drag strip!
Yessssssssssssssssssssssssssssssss
Orr89rocz
Post by Orr89rocz »
mag2555 wrote: Mon Feb 05, 2018 6:43 am Well your heads are tapped out at 5600 rpm, but where do you actually shift the motor at 7200 to 7400?
How do you figure 5600?
swampbuggy
Post by swampbuggy »
Where do you figure it is ? Mark H. :?:
Newold1
Post by Newold1 »
Heads tapped out at 5600! You must have the dyno sheet upside down and reading it backwards. The heads look good to me and the top rpm power readings show the average peak power is now between about 6500 and maybe 8000rpms. Is that where you want your peak power average and how is the car set up now and how are you using the rpms? What bracket times and speeds will the car need to run. It's not a peaky power maker so it should be easier to set up and run if those rpms work for you. JMO
user-9274568
Post by user-9274568 »
I have many customers that use a Jones 266/274 in their 406's..
If this was mine, I would give that 245cc more area at the opening, like 1207ish.
That's just me.
rustbucket79
Volumetric efficiency is on the second page, RH column. 7200 shift point.
79 camaro, 3250ish#, th400, brake, 5600 stall, 4.10 gear, 9x29.5 slick. Car ran 10.0x to 10.2x depending on weather, 60' times in the mid 1.3's +\- with full exhaust and a 1050 that is down compared to this carb.
The power curve explains why the car was relatively insensitive to varying shift points.
rustbucket79
cspeier wrote: Mon Feb 05, 2018 10:03 am I have many customers that use a Jones 266/274 in their 406's..
That's just me.
Have to run, but are you saying you would open the gasket flanges to a 1207? How far would you blend in?
Stan Weiss
Post by Stan Weiss »
rustbucket79 wrote: Mon Feb 05, 2018 10:13 am Volumetric efficiency is on the second page, RH column. 7200 shift point.
Did you ever try shifting at over 8000?
Stan
JoePorting
Post by JoePorting »
I'd say there's not much on the table. Those are nice numbers. Maybe a bigger stroke like you said would give you a little more. Probably not worth the cost.
Another option would be to upgrade to a Victor Ram. That's what Bigjoe would probably say. :D
Joe Facciano
rustbucket79
Never saw more than 7400 on the track. Now where is that “chicken emoticon” in regards to 8000+ shift points?
67RS502
Post by 67RS502 »
2 things that I see are shift point, need to shift higher.
and 1 3/4" headers, on the small side, hope you have bigger headers in the car.
67 camaro
girly rollers on pumpgas:
62 Nova cruiser
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
GARY C
Post by GARY C »
Orr89rocz wrote: Mon Feb 05, 2018 8:59 am
I wondered the same thing considering it gained 100 hp well past 5600.
