bearing damage
bearing damage
Finally pulled the bottom end out .
All bearings are conventional type steel/ alum.
All mains and rod bearings have same wear patterns.
Cratering/ dimpling. What do people make of it?
Looks like fatigue to me with bearings beginning to break down.
Would it be a side effect of oil starvation? Excessive load as the car has done quite a few circuit miles, or something I'm missing.
Cheers
Cheers
Re: bearing damage
I have always been told cratering in an engine bearing is fatigue failure of the bearing caused by using the wrong bearing type (makeup) for the application. I've never seen it in any engines I have opened though.
Re: bearing damage
What exact bearing brand and style/part number?
Engine application and use?
Re: bearing damage
I could easily be wrong, but to me that looks suspiciously a lot like the cavitation pitting I see on a boat prop from the air bubbles created, pulling molecules from the metal.
I would be checking the oil pump pick-up[ position in the pan, making double sure that it cannot suck any air at RPM.
Re: bearing damage
Bearings are FM std bi metal types. I suspect cavitation also. Maybe time for an accusump. The original sump wasn't baffled as well as I'd liked.
Re: bearing damage
X2-I agree on the could be cavitation??? That is very unusual pitting.CharlieB53 wrote: ↑Sat Feb 03, 2018 11:26 am I could easily be wrong, but to me that looks suspiciously a lot like the cavitation pitting I see on a boat prop from the air bubbles created, pulling molecules from the metal.
Re: bearing damage
Looks like cavitation to me as well. What is the application, clearance, etc.?
Looks like the crank is in contact for almost the full diameter.
Survival Motorsports
www.survivalmotorsports.com
WD for Comp, Manley, Blue Thunder, Diamond
Probe, Holley, Clevite, Federal-Mogul, Scat....
Re: bearing damage
Any sign of detonation on the piston, edge of the head land or perhaps teeny black freckles on spark plugs? Is there any past history of the engine to think it may have been subject to detonation, such as low octane fuel or too much timing, too hot a plug, etc?
Re: bearing damage
That was just what I was thinking. Bi metal bearing the surface may not be as hard or strong as a A series or a tri metal bearing surface is has caused it to pit.CharlieB53 wrote: ↑Sat Feb 03, 2018 11:26 am I could easily be wrong, but to me that looks suspiciously a lot like the cavitation pitting I see on a boat prop from the air bubbles created, pulling molecules from the metal.
Re: bearing damage
2X.
In fact it looks to be in contact right up to the chamfer at the parting joint. Pinching off the oil wedge that way might well cause/contribute to the blistering and would certainly invite failure. Either the bearing has insufficient eccentricity and/or the rod is oval at rest or dynamically.
Re: bearing damage
Finally got round to a proper inspection.
Found this in the bottom of rod bearing no. 3, and pits in number 1 main which is closest to the oil pump.
Can we conclude this is oil starvation & or cavitation?
Re: bearing damage
Crank pits.
