Valve pockets
turbo2256b
Valve pockets
Post by turbo2256b »
I have wondered how many other heads other than like fords mod motors dont have valve pockets
DaveMcLain
Re: Valve pockets
Post by DaveMcLain »
You mean valve reliefs in the pistons? I can think of a few, 318 Chrysler, 440 Chrysler, some Ford 5.0 engines, Oldsmobile 350's, lots of stuff that isn't all that unusual to see.
turbo2256b
Re: Valve pockets
no i mean the pocket the valve sits in
Newold1
Re: Valve pockets
Post by Newold1 »
I am thinking you are talking about cylinder heads like those on 348-409 chevrolet engines where there is no combustion chamber. the valves appear to be flush with the head surface.
roc
Re: Valve pockets
Post by roc »
Newold1 wrote: Tue Jan 16, 2018 7:39 pm I am thinking you are talking about cylinder heads like those on 348-409 chevrolet engines where there is no combustion chamber. the valves appear to be flush with the head surface.
Like typical Diesel heads.
turbo2256b
Re: Valve pockets
i mean the area behind the valve and the and were the port connects to. have always referred to it as the valve pocket
ptuomov
Re: Valve pockets
Post by ptuomov »
“Behind” meaning upstream of the valve head, right where the valve seat turns into the port?
Put Search Keywords Here
turbo2256b
Re: Valve pockets
ptuomov wrote: Wed Jan 17, 2018 12:19 pm “Behind” meaning upstream of the valve head, right where the valve seat turns into the port?
yes thats the area
Newold1
Re: Valve pockets
Post by Newold1 »
I think he is describing the bowl behind the valve backside in the port? I think?
1972ho
Re: Valve pockets
Post by 1972ho »
Would this be the area you’re talking about
4vpc
Re: Valve pockets
Post by 4vpc »
I love quizzes, can I have a P please Bob?
midnightbluS10
Re: Valve pockets
Post by midnightbluS10 »
What's the difference between the previously posted heads and these? Visually, they don't seem to be very different. I've seen plenty of people mention doing pocket work on 4v modular heads. If there's "no pocket", what are they referring to?
JC -
Newold1
Re: Valve pockets
Post by Newold1 »
I'll take a D Bob for Dialect as many of our engine terms sometimes are difficult to translate and use in other parts of the world. :wink:
1972ho
Re: Valve pockets
Post by 1972ho »
The bowls in these heads have already been ported and cleveland bowls have not that’s why they look a little different.
turbo2256b
Re: Valve pockets
dont understand why this was so confusing. have just pocket ported heads quite often always called it a valve pocket.
any rate wondering about thoughts on last i knew of mod motors dont really have a valve pocket. i know 2 reasons ford didnt but all work i have done with fluid and gases flow were a poppet valve is needed a valve pocket is used/needed to keep from restricting the flow to compensate for the valve.
