ECR GM LS Daytona Prototype engines
hoffman900
Post by hoffman900 »
Thought you guys may enjoy this: https://rameywomer.files.wordpress.com/ ... engine.pdf
Bore: 4.075"
Stroke: 3.185"
Displacement: 332.3
Compression Ratio: 11.75:1
Intake Valve: 2.100"
Exhaust Valve: 1.55"
Valve Lift: ~.640" on both.
Intake: Individual Throttle Body - common plenum. Varying restrictor, 2 x 35.4mm restrictors at start of 2014 season. Effective restrictor area 3.05in^2
With the 2 x 35.4mm restrictors:
600bhp SAE @ ?
460lb-ft @ 6000rpm
~300bhp @ 4000rpm
BMEP @ 6000rpm, 208.73psi (14.4bar).
Max RPM: 7500
Service Interval: 3000 miles
-Bob
KnightEngines
Re: ECR GM LS Daytona Prototype engines
Post by KnightEngines »
I got the heads off one of them things here now.
Customer got the whole engine, he's bumping it up to 6L capacity, running on E85 & using it for IPRA (Improved production road racing).
My job is to tweak the heads a little to suit an unrestricted 6L engine.
hoffman900
KnightEngines wrote: Wed Jan 03, 2018 10:21 pm I got the heads off one of them things here now.
What are your overall impressions of what you see? Obviously, they're good pieces.
You have seen the ECR developed LT based 6.0L used in endurance racing, correct? http://www.enginelabs.com/news/cadillac ... -released/
-Bob
midnightbluS10
Post by midnightbluS10 »
Edited.
Please delete
JC -
pamotorman
Post by pamotorman »
this year they will use 5.5 liter engine the same as the corvette race team has been using built by the GM race shop
CGT
Post by CGT »
That is one thing I couldn't find in the article. What cylinder head is on these things?
hoffman900
CGT wrote: Thu Jan 04, 2018 9:09 am
https://m.ebay.com/itm/GM-Racing-LS7-CN ... noapp=true It’s a special GM Racing casting.
-Bob
CamKing
Post by CamKing »
I'm designing cams for one of the competing engines, right now.
They're limited to 600hp.
The key is going to be trying to make 600hp sooner, and hold on to it longer.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
CGT
Post by CGT »
hoffman900 wrote: Thu Jan 04, 2018 9:36 am
Thank you. Very interesting. Anyone know what rocker arms are required? Or do they use production LS7 pieces? I'd like to have a set of those heads for sure, I want a closer look. :P
hoffman900
CamKing wrote: Thu Jan 04, 2018 10:43 am I'm designing cams for one of the competing engines, right now.
Mike,
How does a cam designer go about doing that? An observation I've made is a lot of restricted engines have more exhaust duration than they would otherwise, but have less overlap.
CGT wrote: Thu Jan 04, 2018 10:49 am
It was posted somewhere else that they use LS1 type rocker pads, but likely it's a special piece from T&D. I would imagine you could just call them up and its a standard part number.
-Bob
CamKing
Post by CamKing »
hoffman900 wrote: Thu Jan 04, 2018 10:49 am Mike,
This is different then a NASCAR restrictor plate engine.
These engines can make over 600hp, but are not allowed to. IMSA dyno's them.
What we've done in the past, is design the engine to make as much power as possible, and then knock the peak HP back down to the required limit.
This has been done done legally, and illegally in the past. One team, that will remain nameless, had 2 different maps. One they raced with, and one that detuned the engine by 40hp, when they dyno tested it.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
hoffman900
CamKing wrote: Thu Jan 04, 2018 12:06 pm
Thanks Mike. I know others who have to run with SIRs (similar design as this, just like FSAE), and was curious how you would go about designing a cam when you go from an no-restrictor to a restrictor set-up.
-Bob
CamKing
Post by CamKing »
On the FSAE engines, we run very short exhaust durations. 20 degrees shorter then the intake.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
DaveMcLain
Post by DaveMcLain »
Who comes up with rules like this?
hoffman900
DaveMcLain wrote: Thu Jan 04, 2018 12:36 pm
Inlet restrictors work great when trying to equalize different engine and chassis combinations. It's just another challenge for an engine builder.
SCCA GT-Lite-GT2 uses them, FIA / IMSA / FSAE also use them.
I never understood the hate. Lots of classes with restrictions on intakes, throttle body diameters, porting, or valve size do the same thing. Eventually it chokes somewhere at some RPM and you build the motor to hold on to that power as long as possible after that point. The cylinder doesn't know where the restriction is coming from.
Only few classes, or bracket racers, can ever worry about sizing everything to whatever RPM peak they really need. Everyone else has to work around something.
-Bob
