EMC 2017 353ci SBC
Rick360
EMC 2017 353ci SBC
Post by Rick360 »
Thought I'd start a thread about our (Creason Racing Engines' Team) winning engine in this years (2017) Engine Master's Challenge, Traditional Muscle class. This was really a team effort to get this engine done and up to par to win.
Our team was the same group that entered in 2011 under Randy's name and finished 5th
TeamMembers: Name (Speedtalk Name)
Joe Creason (creasonracingengines)
Rick (Rick360)
Randy (randy331)
Chad (CGT)
Rick Haynes (not on Speedtalk)
Here's a link to the rules we had to build to - http://st.hotrod.com/uploads/sites/21/2 ... 092117.pdf
353ci Small Block Chevy
570HP at 6500rpm
507 ft-lbs at 4800-5000
Block: Chevy 010 350 block
Fully prepped by Creason Racing Engines
Bore: 4.005"
Stroke: 3.500"
Comp Ratio: 11:1
Pistons: JE custom with lateral gas ports
Rings: Sealed Power gapless .043 rings
Heads: Profiler 185 heads ported by Randy - 50 degree seats Randy can post flowZ but around 290cfm intake
Head Gaskets: Cometic
Intake: World Products Motown ported by me
Carb spacer: not allowed
Carb: Braswell 4150 type 1.75" throttle bore (Creason's dyno carb)
Cam: COMP Cam nitrided flat tappet 238/244 105LSA with Crower rockers to give just below .600" measured lift at valves
Lifters: Trend Products lifters with oil hole in foot (std .842" diameter)
Oil Pan: Milodon steel for Nova
Headers: Doug Thorley 1-5/8" into 2-1/2" collectors tri-y
Here's the best dyno test at the contest.
link below to Hot Rod's article ... it has a few errors but some pictures of the teardown etc.
http://www.hotrod.com/articles/get-570- ... -pump-gas/
This comment in the article about low lift flow is absolutely wrong. Low-lift flow is NOT what we want.
"The Creason Racing team’s strategy was to focus on valve-seat profiles to enable high intake and exhaust velocity and low-lift flow while preventing reversion with the goal of creating a broad torque curve. The initial valve-seat angle is 50 degrees."
Rick
Re: EMC 2017 353ci SBC
Post by gmrocket »
Great build Rick...you killed it with that big flat TQ curve.
steve cowan
Post by steve cowan »
to rick,randy and chad,
congratulations on your EMC win simply amazing
the time and effort into R and D over the course of the year leading up to EMC i suspect would be nothing short of exhausting in my opinion,to make 570 hp with a flat tappet cam as well as the rule restrictions that i read and also to peak at 6500rpm and the power does not fall off is way cool
i worked out that the min CSA is approx 2.15'' with a 195 ish runner, is that a fair assessment ?
also the other thing i am curious about is was there an issue with getting rocker geometry where you needed it with the 1.8 - 1.85 rockers or was it simple enough,
and i really like that power through a set of tri y with a 2 1/2 collector and mufflers to boot
who would of thought.......
i hope randy and chad might chime in with some information about the lead up and days of the EMC,what is the atmosphere like,how are the other teams friendly i hope ??
it is all cloak and dagger type stuff
anyhow thank you rick for taking the time to share
steve c
steve c
"Pretty don't make power"
Walter R. Malik
Post by Walter R. Malik »
This is real proof that although some individual parts may be deemed better in their own right ... it is definitely getting the entire combination of "right" parts working together which gets to this type end result.
Great job ...
CGT
Post by CGT »
steve cowan wrote: Sat Dec 30, 2017 3:38 pm also the other thing i am curious about is was there an issue with getting rocker geometry where you needed it with the 1.8 - 1.85 rockers or was it simple enough,
Rockers were backset trunion which helped, but it really wasn't ideal as far as geometry. It pretty much married us to a 5/16 pushrod. The geometry would have been better with less ratio, but it just wasn't an option. Wouldve taken more unwanted duration to gain more lobe lift. And, the motor responded to every bit of lift it could be given.
Carnut1
Post by Carnut1 »
Much respect. Thanks for sharing.
Roundybout
Post by Roundybout »
Thanks for sharing. That's a stout piece given the rules. Just curious, are the oil and coolant temps accurate?
CGT
Post by CGT »
Roundybout wrote: Sat Dec 30, 2017 5:15 pm Thanks for sharing. That's a stout piece given the rules. Just curious, are the oil and coolant temps accurate?
Yes. Cant vouch for UNOH's dyno but should be.
Casper393W
Post by Casper393W »
Great job guys!! It goes to show what a great combination can do!
swampbuggy
Post by swampbuggy »
Did not see any carbide burr finish anywhere in pictures i saw, what about intake manifold finish if you guys don't mind saying ? Thanks Mark, and congrats on you WIN !!!
mtrhead
Post by mtrhead »
Great write up
Do you know at what rpm did the 390” setup start running out of steam because of those headers?
I purchased those tri-y headers late last year for my street only sbc. Looking forward to using them this spring to gain some torque versus various 1.75”headers I’ve used.
77cruiser
Post by 77cruiser »
Nice job!! D shape ex ports? If so how did they fit up to the headers?
Jim
GARY C
Post by GARY C »
Good Job!
zums
Post by zums »
What??? no low lift flow, how can that be. :lol: The build shows what thinking as opposed to robotically building or reading published bullshyt an engine is about. Well how much do you want to divulge,, by the time the valve hits .25 l/d your not far from max allowable lift so ill guess 86-87% throat, an intake lobe with more area on its back ,i know the mowtown has a little more avg csa than the super victor but a little less then the 2814 stock, what csa avreage did you end up with after porting. Would creason divulge rvk numbers, turn over tq, again good job guys, thinking about all the variables that effect how we think an engine actually breathes dynamically is alot more difficult then most people want to think about .
Tom
Rick360
Post by Rick360 »
mtrhead wrote: Sat Dec 30, 2017 9:27 pm Great write up
The peak hp rpm on the 390ci didn't really change between the 4-1 and tri-y. The tri-y helped below 5k or so and hurt above that but it didn't really nose over any sooner. They just flattened out the hp curve. The EMC score on the 390 was nearly the same between headers. The tri-Y's just happened to be the right size for the 353 and gave it the advantage.
I'd have liked to try a 4-1 with 1-5/8" and a 2.5" collector. On most headers the collectors are too big for the primaries IMO. Nobody makes smaller collector headers.
You'll like those headers on a street car.
Rick
