Engine Masters' Air Filter Test
DaveMcLain
Post by DaveMcLain »
I saw this video over on Youtube and I thought it was very interesting. Their results seem to be very similar to what I've observed on my own but I've never tried the velocity stack. In the past I've seen that putting the carburetor top way down in a hole using a spacer under the filter base can be very bad for the fuel curve. Interesting stuff none the less:
https://www.youtube.com/watch?v=EkpsydS8JXI
RevTheory
Re: Engine Masters' Air Filter Test
Post by RevTheory »
Definitely interesting. I'm surprised that big block didn't swallow some of those filters, lol.
pamotorman
Post by pamotorman »
I wonder if the length of the bowl vents caused the problem with the dropped bottom air cleaner being too close to lid ??
lefty o
Post by lefty o »
time for the salad bowl.
Krooser
Post by Krooser »
lefty o wrote: Mon Nov 13, 2017 10:45 am time for the salad bowl.
Would the choice of dressing make a difference?
Zmechanic
Post by Zmechanic »
Krooser wrote: Mon Nov 13, 2017 10:48 am
Depends if the dressing is leaded or unleaded
plovett
Post by plovett »
I thought the most interesting result was the K&N filter lid with the sides taped shut. It was kind of like a short wide velocity stack.
paulie
Krooser
Post by Krooser »
One of the engine builders I know told me they dyno tested those 'filter tops' and the K&N 'knock-offs' just killed the HP while the brand name one did about as expected... just a little better than none.
racinnut15xm
Post by racinnut15xm »
Disappointed no R2C was involved in that testing. Off to find a nice used salad bowl :D
GARY C
Post by GARY C »
I was wondering when they would post that vid.
Circlotron
Post by Circlotron »
Amsoil was the sponsor and they didn’t try out an oil bath air cleaner.
Unbelievable!
RDY4WAR
Post by RDY4WAR »
I was hoping to see the salad bowl without the filter media compared to the open velocity stack.
lefty o
Post by lefty o »
RDY4WAR wrote: Mon Nov 13, 2017 9:21 pm I was hoping to see the salad bowl without the filter media compared to the open velocity stack.
it probably would have won. :lol:
Circlotron
Should also have tried a properly shaped velocity stack like you see on some turbo inlets nowadays.
KnightEngines
Post by KnightEngines »
That agrees with my testing.
'extreme top' did nothing, best for HP was a regular 3x14" K&N with a chrome lid - on a 600hp small block.
