Cheating up chevy stock class 350
rdkonkel
Post by rdkonkel »
I’ve seen Brzinski heads and undercover porting, so what else are these guys doing to sneak performance out of stock class 350’s?
CamKing
Re: Cheating up chevy stock class 350
Post by CamKing »
Depends on what the rules state, and how they're checking them.
What's the rules. regarding camshafts ?
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
rdkonkel
Post by rdkonkel »
No lift rule, solids, stock diameter lifter,
Stock or dart s/r heads (no vortec)
Edelbrock 2701 intake
9.5:1
360 max
CamKing
Post by CamKing »
That's not what I would call a stock class 350. More like a pro-mod.
Your biggest advantages will be in the heads and manifold, and it all depends on what you can get away with, without being caught,
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Post by PackardV8 »
Thin rings, light pistons/rods/crank/damper/flywheel.
Coated pistons, valves, chamber, exhaust
7mm valves (he got away with that one longer than you'd expect, as head diameter was correct and with a lash cap, tip looked right.)
A two-core-plug 400" block and crank with #1 hole sleeved to 4" and first rod journal destroked to 3.5". Only worked back when they always checked #1 with the P&G.
pamotorman
Post by pamotorman »
rdkonkel wrote: Sun Nov 12, 2017 2:48 pm I’ve seen Brzinski heads and undercover porting, so what else are these guys doing to sneak performance out of stock class 350’s?
if it is circle track racing work on the chassis as there are 4 turns and only 2 straights. I tell them till your driver can drive the whole track without lifting you don't need more power. winged sprint cars is the place HP is king
I thought that unless you can get wheelspin at the end of the longest straight you don't have enough power. :lol: (and if you can, you need more wing...)
rustbucket79
Post by rustbucket79 »
That's pretty pathetic that some loser would run undercover ported heads in an entry level class. #-o Car owner should be fined and car crushed for his efforts plus public shaming seems like a fair punishment. [-X
ZIGGY
Post by ZIGGY »
The best thing most racers at this level can do for their engines is a set
of heads by someone who knows what they're doing. This excludes 90% of
the yahoos who offer half-ass machine work to local racers. This doesn't
mean Brzezinski top stage type work. Just top quality racing valve job on
good casting choice with whatever chamber, bowl and port massaging that their
knowledge and experience tell them will bring best results and pass.
Combine the heads with a carefully selected cam and correctly set up valve train.
I promise this will put your engine ahead of most, that is until the half-ass built
short block blows up and destroys the good heads and cam :lol:
