***Post Pics of what you are working on**
mdengine
Re: ***Post Pics of what you are working on**
Post by mdengine » Thu Oct 12, 2017 8:53 pm
Cutting seat on a flat head
Carnut1
Post by Carnut1 » Fri Oct 13, 2017 5:57 am
I shall not covet, I shall not covet, I shall not covet, your Serdi.
mag2555
Post by mag2555 » Fri Oct 13, 2017 6:41 am
Joe I have been doing electronic repairs since 74 and repaired more color TVs , receivers , CB radios and restored more vintage guitar amps then I care to think about!
I have been using WD-40 on Pots for 30 years with no issues!
What your seing is the fact that some pots have some much Carbon dust in them that if you do not use a cleaner to flush them out first, or even taking them apart to do so then the scratchyness will come back once the lube be it WD-40 or Pot cleaner / lube evaporates!
On pots that I have to go thru the extra step of unsoldering and taking apart I use silicone grease to lube up the Carbon track and that never evaporates!
rfoll
Post by rfoll » Sat Oct 14, 2017 6:47 pm
I haven't started working on this yet, but I need to somehow get it off the trailer. The pinion yoke is up against the floor board. The welds broke and the threads pulled on the CalTrac bar. It looks like the stock drive shaft is toast. I needed to upgrade these parts, looks like I waited too long.
stealth
Post by stealth » Sat Oct 14, 2017 6:57 pm
What welds broke? Center housing to axle tube?
Kbails
Post by Kbails » Sat Oct 14, 2017 9:16 pm
PICT0351.JPGPICT0352.JPGI haven't started working on this yet, but I need to somehow get it off the trailer. The pinion yoke is up against the floor board. The welds broke and the threads pulled on the CalTrac bar. It looks like the stock drive shaft is toast. I needed to upgrade these parts, looks like I waited too long.
did the center spin on the tubes? or did the perches break off?
Long Island, NY
GARY C
Post by GARY C » Sat Oct 14, 2017 9:31 pm
Thats why I went to a pinion snubber and just used my Cal Tracks to adjust left and right as needed, they will still bend over time but you can catch it.
This car is leaving on the snubber.
https://www.youtube.com/watch?v=6RgKOCo0GhU
rfoll
Post by rfoll » Sat Oct 14, 2017 10:05 pm
The center spun on the tubes. There were only about 3 threads engaged on the front tube on the driver side. When you adjust the bars, you don't know how much thread engagement is there. It never occurred to me to check it, the equipment is designed for the application. I suspect I need 1" longer tubes. It felt like the mother of all launches, 50 degrees, dry air, and sea level barometer, until it broke 3 lengths out.
GARY C
Post by GARY C » Sun Oct 15, 2017 12:19 am
Yeah that would be scary, the rear on the car I posted in the vid had to have the rear replaced once in about 8 years due to distortion but the tubes were not welded to the center section beyond what was done from the factory. I have seen where guys will drill the cast center section and do more plug welds, some feel that trying to weld around them will cause a weak point...Consult a professional! :D
Turborick
Post by Turborick » Sun Oct 15, 2017 1:04 am
Hope to run it next week end
Rick Yacoucci
Nebulous Theorem III.V
http://www.bonnevillestreamliner.com
Rick Finsta
Post by Rick Finsta » Sun Oct 15, 2017 10:12 am
Land speed car?
rfoll
Post by rfoll » Sun Oct 15, 2017 11:11 am
I wondered about welding the outer edge of the center, you share my concerns.
rfoll
Post by rfoll » Sun Oct 15, 2017 11:12 am
14567978_10211241240416662_2963183980247069396_n.jpg21761652_10214778109876188_1812262841439958557_n.jpg
Please post your results.
Turborick
Post by Turborick » Sun Oct 15, 2017 12:13 pm
Land speed car?
Yes we will be running @ El Mirage next weekend
Rick Yacoucci
stealth
Post by stealth » Sun Oct 15, 2017 12:20 pm
I like to drill and tap a large diameter cap screw through center into tubes. Basically pins the tubes in place.
Countersink the head with a tight fit.
Just make sure bolt doesn’t touch axle.
