4.6250 piston in a stock 350 block
Can you figure out how to put a 4.625 piston in a stock 350 block?
This is a stupid question to waste your time.
Please make 20 pages of posts arguing about it.
http://www.schmidtmotorworks.com Aerospace Machine Work: Prototypes, Tooling, Molds.
- John Wallace
Re: 4.6250 piston in a stock 350 block
What's the bore spacing on a sbc 350?
Helping the post count.
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
Shouldn`t that be at "advanced tech"?
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
Only if it scales!
No problem, I do that all the time with 1960's, 283 blocks and make over 4,000 HP with no failures.
How much bore energy would that give us?
If we take 4.625 and subtract that from 350, then add 7.56113 ( that number makes the formula work because its a 4.625 bore) that will give your the bore energy.
I'm off on vacation tomorrow, if anyone would like a free sample of my program, just make a pre-order for my new book. I may mention you in it of you tell me your tricks and trade secrets.
The equation doesn't work unless you use PI in it.
All good equations use PI....since it's an irrational number
Mark O'Neal wrote: ↑Sat Sep 30, 2017 2:50 pm[The equation doesn't work unless you use PI in it.
All good equations use PI....since it's an irrational number[/b]
That's why I simplified this formula, so you don't need pi.. we just manipulate the data until the equation works.
Who doesn't like pie?
- bigblockmopar
- bigblockmopar
On a similar note, I would like to see someone come up with the proper way to install this 10" piston in a 426 Hemi...SchmidtMotorWorks wrote: ↑Sat Sep 30, 2017 1:34 pmCan you figure out how to put a 4.625 piston in a stock 350 block?
One thing I forgot to mention, a 4,625" piston will make at least Twice (double) the horsepower in a 327 block VS a 350!
