mag2555 wrote:Well in the first photo the pair of ports on the left are off set such that it would not hurt the flow, but with the pair of ports on the right that's a different story, as that off set is making for a tighter bend !
The Gaskets themselves look good to me and with the exit of the runners being so much under sized I do not see a issue once a normal port match is done but for what I posted about those right side pair of runners, as getting those right will take more work then just a port match!
Also a factor is these are cast to work with the peanut port heads too!
I hope your buddy understands that with amount of cid and today's other Manifolds for these oval port motors that there is no need for a 2-4bbl tunnel ram unles your into the eye candy of it ,or buzzing the motor up to the needed 8000+ rpm with that cid to use it!
Peanut port heads intake ports are wider than they are tall!
