Pump Gas 555 CID BBC, 10 to 1....Dyno 880 Plus...
cstraub
Post by cstraub » Wed Aug 16, 2017 5:39 pm
Pump Gas BBC 555 dyno'd on KY 93 octane 10%Eth.
Straub Tech valvetrain and custom Solid Roller camshaft
Morel Black Mamba lifters
Scott Foxwell worked his magic on these Edelbrock Victor Castings 2.300/1.900 No valve change, stock size on this head.
Eddy Tunnel Ram
AED 750's out of the box.
Chris Straub
Performance Mfg.
http://www.straubtechnologies.com
www.distributorgears.com
F-BIRD'88
Re: Pump Gas 555 CID BBC, 10 to 1....Dyno 880 Plus...
Post by F-BIRD'88 » Wed Aug 16, 2017 5:47 pm
Thumbs UP!.....
cab0154
Post by cab0154 » Wed Aug 16, 2017 11:22 pm
115% VE at that compression is awesome!
Old School
Post by Old School » Wed Aug 16, 2017 11:53 pm
cstraub wrote:Pump Gas BBC 555 dyno'd on KY 93 octane 10%Eth.
Eddy Tunnel Ram
In a decent bracket car what should this engine run at 3400 lbs, glide, 4.56 ?
Racerrick
Post by Racerrick » Thu Aug 17, 2017 12:48 am
cough cough. Really Straub? Is that 555 suppose to impress us or are you just pimping more Morel parts to help your bottom line? I figure you must be a paid poster.
...... Stock $100.00 ford 460 d9te block .065over + Pump gas + 4.6 stroke Ohio crankshaft + No porting on A460 heads+ single 1150 dominator, Comp Cams lifters and cam = 566cu in and over 900 hp...... viewtopic.php?f=38&t=50568
greywolf
Post by greywolf » Thu Aug 17, 2017 12:51 am
When I turned 47 years old, I entered into my 5th decade of drag racing.
GARY C
Post by GARY C » Thu Aug 17, 2017 2:55 am
Racerrick wrote:cough cough. Really Straub? Is that 555 suppose to impress us or are you just pimping more Morel parts to help your bottom line? I figure you must be a paid poster.
10 more ci, 1.5 more points of compression, bigger cam, better heads, AV gas fuel mix and a claimed "900 hp at 6700" with no dyno sheet... So 6 horse power?
Although you were thorough on the product names, I will give you that.
Orr89rocz
Post by Orr89rocz » Thu Aug 17, 2017 8:03 am
The build was for a customer that had specific goals and this was the result. Near 900 hp at low rpm and has to live on pump 93 gas and live on the street. If it was an all out drag car a few points more compression, bigger cam and valve in the head, 900-1000 likely would have been made.
Frankshaft
Post by Frankshaft » Thu Aug 17, 2017 9:36 am
Nice job. Not that you really care what I think I am sure, I don't always think everything is happy. That looks like reasonable power for the components used. Unless the cam is like 240 at .050. Victor 24's or 26's? The new style Eddy tunnel ram?
cstraub
Post by cstraub » Thu Aug 17, 2017 10:20 am
Here is the engine:
Chris Straub
Performance Mfg.
Racerrick
Post by Racerrick » Thu Aug 17, 2017 10:29 am
Where is the question in OP post ??????. 99.9% of the threads on this forum are asking a question. Not serving an agenda and that is the point. Straub is selling his wares and thumping his chest. I find it annoying as this forum IS NOT for selling Straub cams, Morel lifters and Foxwell heads. He has been warned on the other forums for posts of this nature. For the parts used his motor is nothing special for a solid roller 555 with 2x750 carbs and ported heads just like the one I built for my customer. OP post belongs in the show and tell section.
Racerrick
Post by Racerrick » Thu Aug 17, 2017 10:37 am
Actually my build is a little low on hp for a 566cuin A460 headed motor and I'm sure if I lost a point of compression and put on a tunnel ram with 2 750 it would be a wash.
I provided all the important part numbers and techniques used that so anyone could copy the engine and get the same results. Did OP?????
cstraub
Post by cstraub » Thu Aug 17, 2017 10:45 am
Rick,
If you will loosen the intake lash sir by around .004" and tighten the exhaust lash by .010" you will pick up at least another 40HP sir. For more increase I would advance the cam another 4 degrees to supply that demand on the heads.
Chris Straub
Performance Mfg.
cstraub
Post by cstraub » Thu Aug 17, 2017 10:50 am
Frankshaft wrote:Nice job. Not that you really care what I think I am sure, I don't always think everything is happy. That looks like reasonable power for the components used. Unless the cam is like 240 at .050. Victor 24's or 26's? The new style Eddy tunnel ram?
At the end of the day the customer is happy. Cam is in the 260 duration range and a little over .700 lift net. Heads on the engine are 79555.
Chris Straub
Performance Mfg.
Old School
Post by Old School » Fri Aug 18, 2017 9:43 am
Eddy Tunnel Ram
Chris, I really would like your best guess at this. I am working on a similar project but doubt mine will make this kind of power. I know that how fast the car runs "depends" on a lot of things but lets just make say the car will hook and go down the track, not as effeciently as a well sorted out super stocker, but just a good working bracket car.
