BBC thoughts
Re: BBC thoughts
prairiehotrodder wrote:are you teasing me? If i change the tail lights it requires a different cam.
How many tunnel Rams have you used? And tuned?
You can do what ever you want. Being a smart ass doesn't help.
As a GENERAL RULE, unless you have something really [DELETE THIS POST] up, you can take 4-6* off the duration and pull the LSA back 3-4 degrees.
If you don't, the engine will run up higher and loose mid range power.
If you can't call a good cam grinder and ask them, that on use. I started using TR's in 1982 and still use them. The ONLY exception is the car I have now, as I don't want to cut up the hood or change it. Otherwise it would have a TR on it now. In fact, the TR is in the shop, under the bench.
Go back and read all the comic book tests done on TR's, or even on any intake and see how many times they change the cam to match the intake, let alone the carb.
Bull shit dyno tests.
Re: BBC thoughts
cstraub wrote:I disagree. If you don't change the demand or the heads then the same cam will work. Tunnel ram will increase the power throughout the same range as the single plane. Average power increase.statsystems wrote:prairiehotrodder wrote:Electric water pump, electric fan are now on the car and the cam is in at 103 ICL from 108. Good September air is coming soon.
Looked at a couple tunnel rams today. The Weiand and the Edelbrock Victor are my main 2 choices. The Eddy looks to have shorter, straighter ports while the Weiand is taller more curved. The Weiand is also cheaper.
Brian
You do realize a TR takes a different cam than a single 4 right?
I agree, if the heads are holding up. Most of the time they aren't.
Re: BBC thoughts
i believe you. Your short post seemed sarcastic thats all.
Re: BBC thoughts
prairiehotrodder wrote:i believe you. Your short post seemed sarcastic thats all.
I didn't mean to sound sarcastic. I said it because they should call for two different lobes. 9 times out of 10, the heads aren't holding up the induction. The intake is. So the cam is chosen to help a weak induction make power to whatever RPM you want. Then you take the cork out of the system, and use the same cam. Peak power goes up, as will peak power. But the mid takes a giant shit. That means at the gear change and pulling back the gear change, the car will be slower.
That's why peak numbers can go up, but not gain ET. I've seen it many times. I've been using TR's on street cars for decades. If you don't mind a hole in the hood or a scoop there is no reason not to do one.
The exception would be the cross ram. I love those things. If I could find one that I wouldn't have to send my wife into whoredom to afford I'd do another one. They take some work, but they will work.
Re: BBC thoughts
You can get that change (if nessessary) to see, using that current cam by playing with the lash setting and installed phasing, It is advanced now, so.....
But that is a good reason why I wanted you to keep the Straub roller cam too.
IMHO
The big Edelbrock Vic Ram may give up a bit down very low
(it really likes to rev up and make top power) But the Weiand hi ram will gain everywhere that matters on this street car with 10:1cr.
The heads are fine..
One thing I like about the Edelbrock Victor Ram is you can take the top off and play with the internal plenum shape and volume.
EG: if say you want a longer effective intake runner length add a filler insert that fills the whole floor of the plenum with new raised runner entrances, then add a spacer to the top to readjust carb height and plenum net volume. This makes that tunnel ram Tunable/adjustable.
Filler inserts (contour and volume) in the tunnel ram Plenum need not be permanent.
Not as easy (but not impossible) on the Weiand.
The Weiand is tuned to a lower rpm resonance (runner length) and I believe the runner cros section is going to be smaller than the VIc Ram. The Victor Ram 2R is a serious piece and will tend to want more compression ratio, cam duration and RPM.
BigJoe1 may be a good person to get advice on which intake will be best for you
on this 10:1 motor and which will be best on a 555 with more cr.
You might PM him.
IMHO
You might PM him.
Re: BBC thoughts
I'd still like you to try the 2x4's on a carb adapter, for grins.
You'll be screaming my name like a B%^^&&^% all the way down the 1/4 HA HA HA
Re: BBC thoughts
You might say that having 2x4 carbs on a carb adapter, on your supervic single 4bbl manifold might look kind of wonky,, but need not be at all if when enclosed in a cool "shaker" hood scoop with integral carb box attached.
using this
Inside the scoop there is enough room for a fabricated "precleaner" filter
to both take the big dirt out of the fresh air and slow- and straighten the in flow
a bit. Now the carb(s) will meter properly at high vehicle speed... This will keep the dirt out of your expensive street 540 BBC, protecting your $investment$.
using this
Re: BBC thoughts
Like this?statsystems wrote:...The exception would be the cross ram. I love those things. If I could find one that I wouldn't have to send my wife into whoredom to afford I'd do another one. They take some work, but they will work.
David Vizard and others say that stock, the dual plenum designs like mine here (previously converted to Lucas timed MFI), have terrible distribution/resonance issues, hence I'll fabricate a much larger balance duct for A-B testing when I get my 498" BBC together.
Re: BBC thoughts
I don't recognize that intake. The intakes I used all had removable tops.MadBill wrote:Like this?statsystems wrote:...The exception would be the cross ram. I love those things. If I could find one that I wouldn't have to send my wife into whoredom to afford I'd do another one. They take some work, but they will work.
That's pretty cool right there. I'm trying to remember if the 302 chev CR had a removable top. Been years since I've seen one.
Re: BBC thoughts
prairiehotrodder wrote:Hey F-bird
where do you live?
https://www.kijiji.ca/v-view-details.ht ... stSource=b
Dam, Brockville Ontario is far away, way on the other side of Lake Ontario from me. (A 5 hour drive...
But give 'em a call or email. It's big, but not heavy to ship to you....
ya struck gold...
Re: BBC thoughts
The name's been ground off; I keep meaning to track it down; I think it might be an Edelbrock XC96.statsystems wrote:MadBill wrote:Like this?statsystems wrote:...The exception would be the cross ram. I love those things. If I could find one that I wouldn't have to send my wife into whoredom to afford I'd do another one. They take some work, but they will work.
DSCN2256.JPGThat's pretty cool right there. I'm trying to remember if the 302 chev CR had a removable top. Been years since I've seen one.statsystems wrote: I don't recognize that intake. The intakes I used all had removable tops.
The GM factory cross ram was two piece, with a single plenum. I put one on my 1970-1/2 Z28; ran awesome!
- Show Guest
Re: BBC thoughts
When I put a T Ram on an engine similar to yours, it PICKED UP ALMOST 100 HORSEPOWER- The minimum you could get would be between 50 to 70 MORE HORSEPOWER
JOE SHERMAN RACING
JOE SHERMAN RACING
