Need 6.1 Hemi Valve Seals with .525" Guides
I Need 6.1 Hemi Valve Seals with .525" Guides. Looking for viton steel body seals but i cant find any for .525" diameter guides. The closest that I see are .530". Will the .530 seals work and be tight enough or just settle for the flex body viton seals. Thanks in advance.
-Poppy
Re: Need 6.1 Hemi Valve Seals with .525" Guides
I got my 6.1 hemi valve seals at the Dodge Dealer.bigpoppapreston wrote: I Need 6.1 Hemi Valve Seals with .525" Guides. Looking for viton steel body seals but i cant find any for .525" diameter guides. The closest that I see are .530". Will the .530 seals work and be tight enough or just settle for the flex body viton seals. Thanks in advance.
I should've mentioned that im going with manley locators and wanting to get away from the top hat style seals by using ordinary viton valve stem seals. Reason being is that i have retainer to seal clearance issues with the top hats. My camshaft is .595" both on the intake and exhaust.
-Poppy
http://www.valveseal.com/v-high%20perfor.html
U.S. Seal in Fort Gratiot Michigan may have what I need. Will check Monday.
-Poppy
Also, if you had to, cut them to .500. I used to do that all the time on vortec heads. Cut the .550 seal to .530, and run the seals I like that I usually have on hand.
Harley Davidson sources a viton seal part # 18067-09 that may work for you. Only thing is price wise they're EXTREMLY proud of them.
John
John
