Personal 380 SBC Dyno
I built myself a 380 SBC for my '33 Ford. I decided to use my 205cc CNC heads. I dyno'd at Salina Engine, Salina Kansas, on their new Stuska. We are around 4500 DA.. Made 8 pulls is all. I'm going to do a block and then flog it hard. It has lots of potential!
Stock block 4.155x3.50
SRH v2.35PF heads (205cc)
SRH Holley 300-110 ported/burr finished
2.08/1.600 valves
K-Motion K1650 springs
LGM 1.70 rockers .300 offset
Trend double taper pushrods 8.100 long
Erson 262/268 106 LSA 101 ICL
.690/.660 retainer lift
Crower lifters
Moroso oil pump
Stef's oil pan
Scat LW Crankshaft
Scat LW Rods 6.000
Mahle Pistons 13.5-1 w/gas ports
1.2/1.2/2mm rings
Jesel belt drive
Jesel front distributor
Taylor 409 wires
Innovators West dapner
Starr vacuum pump
Whitener billet 4150
piston .010 in the hole
.0030-.0032 main clearance KING bearings
.0028-.0030 rod clearance KING bearings
.024/.026 ring gap
2.08/1.600 valves
Crower lifters
Moroso oil pump
Stef's oil pan
Scat LW Crankshaft
Scat LW Rods 6.000
1.2/1.2/2mm rings
Jesel belt drive
Taylor 409 wires
Starr vacuum pump
.024/.026 ring gap
Re: Personal 380 SBC Dyno
What looks happy and how do you come to this conclusion?littleben wrote:Looks happy
So here is my thought as I started reading....
I saw "33 Ford" and I thought, "cool... mild street rod cruiser type combo." Then I started reading the specs! LOL
what fuel?
It's a Suncoast built '33 Ford..novadude wrote:So here is my thought as I started reading....
Up close,,,fdicrasto wrote:The shaped dividers in the intake floors are interesting.
any idea how much .200 duration?
186 both says the master list.cab0154 wrote:any idea how much .200 duration?
I was told they used the wrong follower for the report.
Cam looks like it'll live a long life, pretty mild on the lobes - low maintenance engine?
Did you try winding the cam back to 103ICL? - I reckon it may be happier there, but I may be wrong!
Big spread from peak TQ to peak HP - she's not head limited, it'd go more rpm up top if you wanted it too & cammed it up.
I can see 700hp pretty easy with another 4 deg duration on both sides, 103 ICL & slightly more aggressive lobes - say .430" lobe lift.
It's a damn good starting point as it sits!
Would be interesting to run it on E85.
