BBC alternator bracket
prairiehotrodder
Post by prairiehotrodder »
(NEW DESIGN) laser cut 1/4" mild steel mid mount alternator bracket for a big block chevy with long water pump and 9.8 deck height. Works great, uses a much shorter belt to reduce belt throwing and positions the alternator much lower for a cleaner look. Weighs one pound less than the stock 2 piece bracket. Uses your stock alternator pivot bolt and spacer $50 shipped USA or Canada 306-752-5558
$50 USD shipped to USA
$50 canadian dollars shipped to Canada
pay by paypal or E-transfer
prairiehotrodder
Re: BBC alternator bracket
still available.
Post by PackardV8 »
Is this a one-and-only or something you make? I might need something similar with different mounting holes.
USMC_Spike
Location: MotorKraft Mit Uns - East of the Pecos, Tejas
Post by USMC_Spike »
That seems upside down.
Will it work the other way too?
FOUND: new improved smaller non-ricer pic
prairiehotrodder
Its a very simple bracket that just flips the alternator upside down from its stock location. It still pivots on the same bolt. It is $50 shipped.
ProPower engines
Post by ProPower engines »
Much better design then the original bracket where too many misalignments can be found in custom engines where using the end intake bolt and a bolt near the stat housing then find the pulley is cocked creating a belt running off center line and wearing the side more.
