I've disassembled the '70's era GM power window mechanism from my '79 Lotus and ask what lube would be best for the regulator gear and motor pinion bush points. I figure a light oil for the nylon track rollers.
Cheers
Best Lube for Window Mechanism
Re: Best Lube for Window Mechanism
I like white assembly grease for the rollers, and whatever grease you stick in the motor is way better than petrified 1979 grease.
Something with paraffin in it.
Fluid film is what I use.
I have been told to use Loctite Viper Lube
