Does MSD make power?
No.
Neither does a big volume fuel pump either.
A stronger ignition system can allow more power to be made if another lower poweed ignition is not fully doing it's job. Most don't.
It would be amazing to learn in the course of one race just how many times a random cylinder did not have complete ignition.
Will a good MSD ignition system that is compatable with the engine's needs allow more power to be made? In my opinion, absolutely.
The ignition system's job is to get the flame ignited. IF there are hostle conditions in the fire chamber area it will take a stronger initial spark to get it to even ignite. The Digital 7 series of ignitions creates a major spark that usually fires under the most extreme conditions. Exceptions are with SEvere bosted Blown Alcohol and Blown Fuel the Mag 44 system, from MSD is said to provide a more consistend more powerful spark.
In the earlier daus of the MUlti-Spark Discharge from MSD we had jumper connectiuons on the ignition coil, so we could quickly convert back to eliminating the MSD Box from the system. We had first hand proof that at idle speeds there was an idle rpm improvement when the MSD was in effect.
The only reason why the Multi-spark is better and only works at low and moderately high rpm is becuase of the time limitations for each spark with crankshaft revelutions. It gets to the point that before the ignition can fire the plug more than the initial spark firing, the piston is moved to far for any additional fire would be detrimental.
Comparing the intensity of any factory ignitiion system, with no Capacitive Duscharge box, to using a MSD, Crane, Mallory etc. is ludricoulas. The Aftermarket Capacitive Discharge MUlti-Spark ignition systems serve in much more useful functions than just another style of ignitiion module.
Ed
Let all things that hath breath Praise the Lord. Praise Ye' the Lord. Ps-150 vs 6
