by Mike Rogers » Tue Mar 22, 2005 8:06 am
I did do what you said and shorten the push rod .100 it still did not get me to wear i wanted plus it made the geometry so far out of wack the rocker was way on the back side of the valve tip.
Mike Rogers
215-674-5240
EQ Cylinder Heads
http://www.rogersperformance.com
Mike Rogers
by Adger Smith » Wed Mar 23, 2005 11:26 am
Mike,
Sorry I wasn't in when you called.
I have never tried to figure it that way. (Pushrod Length Vs Ratio)
I can say I have found that when working with 1.75 & 1.8 ratio rockers set @ 1 1/2 turns out the ratio changes approx. .25 for every 1/2 turn on the adjuster. At 24 threads per inch one turn is .04117.
Ths only holds true if you have the stand height correct. Hope this helps.
Adger Smith
Return to Engine Tech
Who is online
Users browsing this forum: 67satellite, bert, Bing [Bot], camaro itb, clay, Coloradoracer, englertracing, Google [Bot], greg, gtca9014, Heritrix [Crawler], k-star, racear2865, rbgracing, Rizzle, SKeown, Vintrcr and 29 guests
