la360 wrote:This is a question for those folk experienced with building Comp Style engines. When does the camshaft profile design start to be hard on, and regularly hurt valvetrain parts?
I have been given a ball park kind of figure, but wasn't able to expand on it during the phone conversation due to time.
Just to give you some parameters, I am talking small block engine, 50-60MM Core, Titanium valves, Jesel style rockers etc.
Would be interested to hear peoples thoughts, and about their experiences, this style of engine is relatively new to me
Many thanks
AL Jones
You simply have to know about valvetrain when you are turning 8000+ rpm no matter what. If you don't feel good about making a decision totally on your own and you probably don't right now or you wouldn't be trying to expand your knoqwledge, then do as these guys are telling you and get some first hand knowledge from the cam guys themsleves about what is generally run. They can give you some pretty stable systems and lobes that you shouldn't have any problems with.
You can use lobes that are made to turn 10000 rpm and last a while and then there are lobes that are made to be
much more agressive and will eat springs and valvetrain parts right and left. If you don't have lots of time and money to test then get an engineered and tested setup that can turn even more rpm then you think you will, to stay on the safe side of things.
Also be honest with yourself about how much rpm you can afford and what parts you can really run as well as how long they need to last and you'll make a much better decicion in the end when you're talking o these guys. Then after every high rpm engine you do you will start developing your own experiences and understandings further and further and can keep building on them as well as making more intelligent choices even when talking with other engine guys like here on Speedtalk. Good luck.
