High octane fuel burns slower?
Truckedup
Post by Truckedup »
I'm talking about pump gas not race gas. Hear it all the time,93 burns slower than 87 to resist detonation. I been looking around for real info on this and only found a few things.
One from Sunoco's race fuel site saying it's not true for racing gas but has some merit for pump gas.. What does some merit mean??
Other technical info just says that higher octane ignites at a higher temperature to resist detonation...
Anyone have technical information on this? Thanks
mk e
Re: High octane fuel burns slower?
Post by mk e »
Everything I've seen says the burn rate is about the same regardless of octane. The higher octane resitsts pre-ignition better so it burns when you want instead of exploding which you never want....which i guess is "slower" burning in a way ;)
Mark
Mechanical Engineer
The Radius Kid
Post by The Radius Kid »
mk e wrote:Everything I've seen says the burn rate is about the same regardless of octane. The higher octane resitsts pre-ignition better so it burns when you want instead of exploding which you never want....which i guess is "slower" burning in a way ;)
That's correct.
Octane is basically the measure of a fuel's ability to resist auto-ignition.
It's not it's burn speed.
Different fuels with the same Octane number can actually exhibit different burn speeds,once they're started.
Go figure.
CharlieB53
Post by CharlieB53 »
Mike and Radius have the right idea.
Burn speed can be measured in Feet per Minute. The speed of the different gasoline are very near the same.
Octane increases the 'flash point of the fuel, the specific temp that the fuel will self-ignite. IIRC it's Bolye's Law, pressure and temp, yada, yada. As compression comes up and pressure rises so does the charge temp. Upon ignition of the charge pressure radically rises, if the octane is insufficient the unburned charge on the far side of the 'cloud' can self-ignite, causeing the knock, or ping from the sudden pressure spike. No longer a curved rise in pressure but a sudden spike.
Lizardracing
Post by Lizardracing »
Speaking of burn rate....Why is ignition timing static in race cars, yet the time the fuel needs to completely burn is continually shortened with RPM?
On a street car, a low static is set, then the burn process is started earlier and earlier with RPM until 3k or so, then is static from 3k or so to redline?
The fuel will burn at a set rate yet we change the rate but not linear with RPM. Why?
Race engines have very poor cylinder filling at low speed, so they need/can use a lot of advance, just as vacuum advance helps during light throttle cruise. Also, they don't get driven much at those speeds, so if the timing is 10° or more from 'ideal' for the conditions, no one cares. As the revs increase, the higher cylinder pressure gives a faster burn, as does the increasing turbulence, so a fixed advance isn't far off for most apps, and can be improved only with a sophisticated spark table and a lot of tuning time.
Splitter
Post by Splitter »
Flame speed increases as rpm increases, but remains the same in terms of crankshaft degrees.
The Radius Kid
Lizardracing wrote:Speaking of burn rate....Why is ignition timing static in race cars, yet the time the fuel needs to completely burn is continually shortened with RPM?
As I understand it,there is a certain amount of "lag" between the rise to max compression pressure and detonation,*if there is a tendency for it to occur*.
As the RPM comtinues to rise,the time for the detonation to occur shortens before the actual spark event happens.
peejay
Post by peejay »
Racers prefer the reliability of having no advance system in the distributor to stick/fail over having a few extra HP.
At least, this is the rationale I gather from reading the commentary when the subject comes up. I don't do circle track, but apparently having a mechanical advance on a 2bbl engine is worth quite a bit of power.
For digital ignition control, the only excuse for having a fixed ignition timing is laziness on the part of the engine tuner.
4sfed
Post by 4sfed »
Three things are required for a mixture to auto ignite . . . time, temperature and pressure. Increase any one of them and you may cross the threshold.
140Air
Post by 140Air »
Truckedup wrote:I'm talking about pump gas not race gas. Hear it all the time,93 burns slower than 87 to resist detonation. I been looking around for real info on this and only found a few things.
This is generally true for pump gas. The Sunoco site is correct. The reason is that pump gas differs in octane rating based on blend. The higher octane gas tends to have more of slower burning, more stable compounds blended in. I think the difference is small.
Race gas is another matter. Same for non-gaasoline fuels. Octane number does not faithfully follow burn speed.
Truckedup
Post by Truckedup »
Ok, but how do you know what you are saying is true? :D What does burning slower accomplish? The longer burn gives detonation more time to happen. Yes?
Mike Croley
Post by Mike Croley »
The term "slow burn" is only relative where race gas is concerned because of the RPM a race engine turns. You want as much of the charge as possible to burn, but at 7000 RPM there isn't much time for that complete burn to happen. Stock street engines don't turn very high RPMs and don't need an extremely fast burn.
Mike Croley
Florida Master Dist. for Renegade Racing Fuels/Methanol
386-341-4308
The Radius Kid
Truckedup wrote:Ok, but how do you know what you are saying is true? :D What does burning slower accomplish? The longer burn gives detonation more time to happen. Yes?
Not really.
You have to control the combustion pressure rise speed or a too fast moving pressure front in the chamber could cause the light end chain gases to pre-ignite,causing the two pressure fronts to collide creating a situation we all know and love so well.
I think I sad that right. :shock:
140Air
Post by 140Air »
Actually, I take the oil companies' (like Sunoco) word for it. I think they know what compounds are best (and cheapest) to increase octane rating and what else they do to the fuel. I do know that some compounds, like Toluene and Xylenes, have a higher flash point and I believe a slower burn rate. They have high octane ratings and are used as octane boosters.
As for the time factor, I think compounds that have the effect of octane boosters help to stabilize the rest of the fuel otherwise their mere presence would not slow the pre-flame decomposition reactions in the less stable components that lead to detonation. The chemistry is complicated. All high octane compounds are not equally as effective as octane boosters for low octane gasolines.
