piston failure
piston failure
I have a piston that failed on a lsx454 crate engine. AFR was 12.-2-12..0 timing 28 degrees , fuel was 100LL. It is a endurance application and usually runs at 5700 rpm at WOT.
My thoughts are slight deto over a long period of time caused it but I amlooking for more thoughts on this. There is 4 other pistons that are starting to crack in the same manner also.
Re: piston failure
Looks more like fracture from thin piston than burn through. IF mixture and timing are as stated, and using av gas 100 octane low lead, I can't see detonation, but I could be way off.
Is the defect in what I see, or what I'm seeing with ?
Re: piston failure
The fuel was actually 103.2 octane. water temp 130 f oil temp 280 f. You can't see it in the pic but there looks to be some slight sand blasting texture going on at the edge of the piston also. I hope it's just to thin as it is the piston we have to use in this class.
Re: piston failure
Another area you might consider is piston pin flex.
What do the spark plugs tell you?
Blessings.........Ron
Creekside Racing Ministry....John 14:6
ProCharger F3-139 blow thru carb gas nonintercooled (6.30 @ 220 mph (done with that)
Currently shaking down Boost referenced MFI alcohol ProCharged system
6.20 @ 240 mph (way more to come)
Re: piston failure
We had to run it for a while after the failure to limp back but we had looked at them the night before and they did look a little lean. We richened up the carb but maybe it was to late already.
Heat as in lean or please explain.BigBlocksOnTop2 wrote:Pretty clean piston...lots of heat.
Re: piston failure
The pebbling at the edge looks like a bit of detonation and that definitely does not look like a piston running at a true 12:1 AFR. I've seen lots of much darker tops on road race Corvette pistons that have run up to an hour at a time at 13-13.2:1..
Is that the relevant wrist pin to the left, appearing a little cooked?
How do the bearings look, especially the rod uppers?
X2 a bottom view of the holed piston as well as a couple of the cracked ones.
How thick are the piston tops?
Any pinched rings?
You'd have mentioned it if you were running boosted, yes?
Presumably there is no knock sensor system on the engine?
Any idea what is peak torque RPM on this engine? That would probably not be a good range to run for endurance.
I don't know what MBT spark might be for that engine, but 28° sounds a little on the high side. You might do steady-state dyno testing and develop a spark table for a couple of percent retard from MBT.
If you're stuck with that piston p.n., thermal barrier coatings would be a cheap precaution. If they aren't approved, Swain for one has an invisible "stealth coating" available.
Piston squirters are more work but if legal would help substantially if other avenues prove to be dead ends.
Any pinched rings?
Re: piston failure
It is NA.
The piston thickness is approx .250 where it broke through.
Yes that is the wrist pin beside the piston.
Yes and the plugs looked leaner that the AFR was showing.(a side note this same thing happened to another competetor 20 min later in the same leg of the race with the same setup and showing the same AFR)
Funny you should mention the knock sensor. I had a J&S electronics setup and and sold it before I decided tio run this engine. (whoops)
bearings look like new both mains and rods. No other rings were pinched other thatn the holed piston, no scoring on the cylinder either.
Peak tq is at 4900 and we run them at 5700.
Yup stuck with that piston and not allowed to do any mods to the engine.
I agree the 28 degrees seems high now and I think you absoulutly right that we did not get a good spark table figured out. Looking back the altitude density was 5500 ft when we dynoed and all of our races have been at 2500 ft air density. 28 degrees timing made best power 29 dropped power slightly (prob some deto) and 27 was less also but obviously safer) Should have know that it may be ok in a drag race but for endurance surely it would push it into some deto. All I can do is replace the pistons and change the tune. just want to make sure that that will do it.
Here is bottommpic of the piston sorry no pics of the others right now.
Re: piston failure
That should be a good indicator that something is not right, especially with 130 water temp.oil temp 280 f.
strangemagicperformance.com
- BrazilianZ28Camaro
Re: piston failure
What compression ratio, cam, spark plugs?
Are you sure the damaged area is 1/4" thick?
Looks thinner by the pics
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
NEW BEST ET
- needforspeed66gt
Re: piston failure
I've seen plenty of pistons cracked through the pin bosses and almost through the crown where the aluminum had gotten just hot enough to sag in the middle but not quite burn through yet, each time it was traced back to a lean condition due to tuning, vacuum leak, or in several cases an odd spark scatter thing on 5.0L ford motors due to spark plug wire routing.
Nate @steeldustmachine
Engine Machinist
Engine Machinist
Re: piston failure
The valve notches look different (less severe, smoother transition) in this picture.
http://image.popularhotrodding.com/f/te ... piston.jpg
Did you have to deepen the valve reliefs?
