536hp 347
536hp 347
i need to thank everyone for their help and contributions.
Joe for the inspiration and guidance
http://www.enginebuildermag.com/Article ... build.aspx
the same for others on this forum wiser than I.
Mike at jones cams
Dick Mceldowney at mid America motorsports
Rich Farnsworth,Jim Kubash,Mike McKenzie and Mike Zordon from Lane Automotive
and most important, God. (especially for the great weather today)
10:1 347ci ford. scat forged crank,I beam rods, SRP Pro pistons, melling (STOCK) pump, canton pan and windage tray, power bond damper, engine pro timing chain,comp cams lifters, JONES SOLID ROLLER, engine pro push rods,AFR 195 heads(UNTOUCHED!!!), T&D sport comp shaft rockers, port matched vic jr. with (blended plenum)Crane distributor/ps60 coil, 750qft crab, 93oct BP, brad penn oil, wix filter.
wont give the cam specs so dont ask! ill tell you that its SMALLER than Joe's. no offense Joe.
536hp @ 6800
475lbs @ 5300
over400 lbs from 3300 to 6900
over500hp from 5600 to 6900
bsfc were mid to low 400's throughout and rich at throughout.
might not be out of this world to some but its the most hp/cube I've done!
very happy customer Mike! Thank you!
Mike at jones cams
536hp @ 6800
475lbs @ 5300
Daniel Brown
Accurate Engine Rebuilding
(269)930-1962
(269)930-1962
Re: 536hp 347
Excellent! Especially your reference to God. That's pretty rare these days. Congrats on a fine build
Shawn
Shawn
- Show Guest
Re: 536hp 347
Looks like you had a good recipe to follow.That was a long time ago.
JOE SHERMAN RACING ENGINES
- needforspeed66gt
Re: 536hp 347
My bread and butter come from agriculture/industrial and service shops in the area. I do less than a dozen hot rod engines a year and very seldom fully assemble them complete with one or two getting dynoed. Being a small one man shop, I cant afford to push limits. 10:1,10.5:1,11:1 more power only shortens the fuse length,reduces reliability and that's not want my customer wanted.We are 36hp more than our goal and 60 more than what we would have been content with.
Daniel Brown
(269)930-1962
(269)930-1962
Re: 536hp 347
late 60's block. cant remember exactly. couldnt get a 2 piece to fit right so had it machined for a one piece. studded and girdled. stock pump made 63lbs @ 6800.
Daniel Brown
(269)930-1962
(269)930-1962
Re: 536hp 347
Good inspiration, I am building a 10.1 357 SBC very similar to this, I have my RHS heads just under 200cc's flowing 299 at .600 lift and looking at running a very aggressive solid roller in the 274 on seat range.
Re: 536hp 347
thats making alot of steam!! awesome job!!
Stephen Johnson #2162
Horace Johnson #2167
SS/D 427 Ford Fairlane NHRA-IHRA
Ex-Jim Van Cleve
1985 Mustang GT N/A 331
Ex-Jim Van Cleve
Re: 536hp 347
Glad it worked out.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Re: 536hp 347
Seems to be asking alot out of a factory 302 block of any kind. People have made more HP, but that was with supercharging and lower RPM's.
Re: 536hp 347
FloydODB wrote:i need to thank everyone for their help and contributions.
Mike at jones cams
536hp @ 6800
475lbs @ 5300
Out of curiosity, what were the journal specs on your scat crank?
I've got one here that is 2.2490 across the board and 2.1235/6 on the rods.
Very little if any taper on either.
Nice Job by the way.
