How to install wet type sleeves (old tractor)
drifter
Post by drifter »
I am working on a case 148 gas engine and the sleeves have to sealing rings near the bottom of the sleeve.Info that comes with them says to use silicon spray to lube the bloack and put them in i have aslo heard of using dish soap. On the top of the sleeve there is no seals at all so i guess the head gasket seals the top of the sleeve to the block. Do you guys put any type of sealer under the sleeve flange? I know in this engine they want the sleeve .003 -.004 higher the the deck so you cant use anythink thick.
Old School
Post by Old School »
I have used dishwashing soap (Palmolive is my favorite for seals and inside of slicks), silicon spray, and in one case Permatex red high temp silicon.
We were rebuilding an old tractor block that was pitted where the seals should fit tight. I didn't know what else to do, we put a light coating of red sealer on the o rings pushed them in the block, installed an old head gasket and torqued the head in place. Let it sit in front of a heater all night. I was a little nervous, but it is still running, no leaks.
Most of the diesel truck mechanics I know use the soap.
Billy
MileHighMan
lube
Post by MileHighMan »
drifter are the seals made of a rubber like material? If they are, I would use the silicone spray on both the seals, and the block. Don't use anything that might soften, or dissolve the seal. Good Luck. Dan.
DOTracer
Post by DOTracer »
Back when I was a kid I worked at my uncles farm equipment shop. I helped the head mechanic alot. He used to put the sleeves/liners in the freezer before sliding them in the block.
Keith Morganstein
Post by Keith Morganstein »
The counter bore area under the liner flange generally does not use sealer.
The typical thing to do is put the liner in without the seals, clamp it down with a hard bar and bolts, the check liner projection with a liner projection gauge or depth mic. If the liner is low or the counterbore area is pitted, it should be machined and shimmed back to spec.
If this is a "patch job" you can use a little thin liquid sealer under the flange, but beware that this usually does not last the expected service life.
The lower seal area should be clean. If it is pitted , fill the pits with JB weld or Devcon epoxy and hand sand them. When installing the liners, be sure the o-ring(s) are not twisted. Use a quality rubber lubricant (that tire installers use) or a mild liquid soap. I use a special tool to put them in, but a block of wood, an eyebolt in a head bolt hole and a prybar work fine. You just want a smooth steady push when installing.
Jeff
Post by Jeff »
I would do like Keith recommended, by installing all sleeves without O-rings and check protrusion. On that engine your allowed .002 to .005 protrusion, but I like to see no more then .001 diffrence between cylinders. As long as you clean up the counter bore good you should not have to install anything under it, the lower sealing area should be pit free and a mild dish soap works well for installing the O- rings. If they are pitted filling with JB weld would work, or I perfer to bore them out and install part of a cylinder repair sleeve and bring it back to spec. There usually is pitting but sometimes the location is deceiving, can always take an old sleeve drill a few holes where the O ring grooves are drop them in and mark it, to see how bad the pitting is in the sealing area.
Jeff
Masher Manufacturing
Post by Masher Manufacturing »
[quote="Max Effort"] Use a quality rubber lubricant (that tire installers use) [/quote]
And that is pretty much Murphys Oil Soap, water and something to reduce corrosion last I checked.
I'd be real tempted just to use straight antifreeze as a lube.
Also be sure to fill the rad with antifreeze rated for engines with liners. There is some formulation difference that reduces corrosion in trapped areas like the base of the liners.
Engguy
Post by Engguy »
For badly pitted lower bore area I have done the JB Weld deal as mentioned above, and no ill effects.
Johndeer sells special Soap for cylinder o-rings. On some Caterpillar engines there is an upper seal that is oiled with SAE30 so it will seal just below the counter bore.
For variance in protrusion height, you have to counter bore and shim.
Check for cracks in the counter bore area.
quickd100
Post by quickd100 »
Do not use oil on the O-rings! Believe it or not Crisco works real well. Dave
[img]http://img.photobucket.com/albums/v514/quickd100/9ff3c690.jpg[/img]
