towing heads and cam question
Kenneth Flippen
Post by Kenneth Flippen »
What's your thoughts on these
http://shop.whiteperformance.com/SBC-CH ... -S-272.htm
Or the assault heads from kmj
I've got a 400 sbc in a square body 3/4 ton crew cab gonna tow a horse trailer with it its bored 20 over with 200cc dished pistons
Question on cam is my understanding a single pattern builds more torque but hurts gas mileage but what's the trade off how much mileage is lost and how much torque is gained I want all my power done at 5000-5500 rpm
Kenneth
wyrmrider
Re: towing heads and cam question
Post by wyrmrider »
I do not know those heads but I do know that the weight savings of aluminum should not be a concern with your rig
200cc??
the head port volume or the piston dish?
what's your deck height
quench?
whose pistons? number?
do the pistons match the proposed head?
I run a Mike Jones cam in my ported head chevy small block, many years of service life
I had a stable with 130 horses so I know where you are coming from
doing it again with today's oils I'd think of a hyd roller- ask Mike
have your flow data available
also ask him about rocker arm ratios
what's your exhaust? mine's rams horns with 2 1/2 pipes
randy331
Post by randy331 »
For towing with good MPG on a SBC, I'd look at the GMPP small port vortec bowtie heads.
I'd want to re-do the valve job and you'll need a dish piston with 400 ci for sure.
Randy
Post by PackardV8 »
Yes, OT, since he didn't ask, but building a 3/4t crew cab truck engine to tow horse trailers; would a 400" SBC be our first choice today? Certainly wouldn't be mine. Love them for a budget performance build in a light car; not so much in a tow truck.
Just asking, given the variety of engines which would bolt in where a 400" came originally, what would others choose for similar $$$?
FWIW, one of the better 2500 swaps I ever saw was a 500" Cad and TH400. Dirt cheap, big low and midrange torque. Your results may vary.
jack vines
CamKing
Post by CamKing »
wyrmrider wrote:I do not know those heads but I do know that the weight savings of aluminum should not be a concern with your rig
There's more to running aluminum heads, then the weight savings.
The aluminum heads will allow you to run more compression(about a half a point), without running into detonation issues.
I'd look at the Edelbrock Performer RPM E-Tec 170 heads.
as for cam design, I'd need to know what RPM the engine is at when you're cruising down the road, pulling the loaded trailer.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
wyrmrider
Post by wyrmrider »
500 caddy- good choice but if he needed real grunt for lot's of miles he'd get a diesel
vortec heads also- better than standard 64 cc heads-- where those in the picture fast burns or what?
google up those kmj heads- procomps?
not very stellar reviews- whose heads are the first pair?
Kenneth Flippen
Type error on the piston its 20cc dish long tube headers 1 5/8" 3" collectors
swatson454
Post by swatson454 »
I don't know... a 9:1, E-Tec headed, MPFI 400 with a hydro-roller that's 208/212 ish on a 108 could be worth looking into. I'm sure Mike would spread the lobes :D
Cruise along at 2,500 rpm, locked up in "D". Maybe?
Shawn
Kenneth Flippen
I'm guessing 2000-3000 cruising
CamKing
Post by CamKing »
If you went with the edelbrock heads, and 9.5:1 compression, and 1.5 rockers.
I'd recommend my Hydraulic Roller. Part# HR65327-67312-111
206/208 @.050"
.490"/.468" Valve Lift
111 LSA
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
cv67
Post by cv67 »
Who the heck is doing their port design. :shock:
CamKing
Post by CamKing »
cuisinartvette wrote:Who the heck is doing their port design. :shock:
Who are you talking about ?
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Kenneth Flippen
CamKing wrote:If you went with the edelbrock heads, and 9.5:1 compression, and 1.5 rockers.
206/208 @.050"
111 LSA
Whats the price on the roller cam and lifter combo
And what would it be on flat tappet cam and lifters
Kenneth
CamKing
Post by CamKing »
Hydraulic roller cam and lifters, about $850
hydraulic Flat tappet cam and lifters, about $300
For a Hydraulic flat tappet, I'd recommend my part# H65295-67300-111, and put a 1.6 rocker on the intakes
204/210 @.050"
,472"/.450" Valve Lift with 1.6/1.5 rockers
111 LSA
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Warpspeed
Post by Warpspeed »
CamKing wrote: 204/210 @.050"
111 LSA
That is a very mild gentle cam, why would it even need rollers ?
Cheers, Tony.
