sbc cracked block
Speed7
sbc cracked block
Post by Speed7 »
Have a 350 four bolt main block with a hairline crack about 3 inches long down number 2 cylinder on the freeze plug side. Have any of you had luck sleeving one and it hold up in a drag racing engine? Mild build 11 to 1 compression 6800 rpm engine.
BrazilianZ28Camaro
Re: sbc cracked block
Post by BrazilianZ28Camaro »
Doing it the right way, the sleeve wouldn't be a problem.
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
Speed7
Post by Speed7 »
My concern is it is a crack, not a gouge. What would keep the crack from spreading on down the block to the oil pan rail and up to the top of the cylinder?
Speedbump
Post by Speedbump »
I would make sure the crack doesn't extend up into the deck and stops before it gets to the bottom of the cylinder. Then, as noted, a properly installed sleeve will work OK. A good guy might also be able to save the deck by trimming the sleeve right down to it and save the cost of decking again. Those blocks are still pretty available so be careful not to get too much money tied up in a sleeved block.
Speedbump
"If it was easy, everybody would do it."
BrazilianZ28Camaro
Speed7 wrote: What would keep the crack from spreading on down the block to the oil pan rail and up to the top of the cylinder?
The best way I know to stop a crack is drill small holes on its ends.
NEW BEST ET
Post by pdq67 »
Might consider taking a Dremal or whatever with a short bit in it and putting an 1/8" hole at each end of the crack so that it doesn't continue to crack longer later.
robert1
Post by robert1 »
It's not a problem.
dontpanic
Post by dontpanic »
I had one sleeved and with in a few races the water started showing up in the oil again, when I pulled it down the sleve cracked in the same place again. maybe bad luck?
this was a +.060 350 block 450 hp dirt track
Good Luck
CNC BLOCKS
Post by CNC BLOCKS »
dontpanic wrote:I had one sleeved and with in a few races the water started showing up in the oil again, when I pulled it down the sleve cracked in the same place again. maybe bad luck?
Good Luck
I have seen that before on performance builds.
Website is up and running
Machine shop tour
Monthly Specials
leahymtsps
Post by leahymtsps »
How thick was the installed sleeve ? Boring some of them .060 will make them pretty thin.
Tom
Post by PackardV8 »
FWIW, you'll get other opinions, but the four-bolt blocks are still available for cheap. If I were building to my own preferences on most later V8s, less bore is more. The more overbore, the more problems.
Having said that, on your relatively mild build, if everything else is right, a sleeve won't be a problem. One of the better running limited budget builds out of here had three sleeves in it. I tried to talk him out of it, but somehow it ran strong and lived long.
jack vines
machine shop tom
Post by machine shop tom »
A 1/8" wall sleeve properly installed with a step at the bottom will work fine. The worst thing will be that the adjacent cylinder will be pushed out-of-round and will need to be honed round again. That will open up the clearance in that cylinder.
tom
Pray for a secular future.
We used to speak to tell things , now they tell things to speak.
Si Vis Pacem, Para Bellum
