CNC BLOCKS wrote:levisnteeshirt wrote:^^^^ so true ,, its a roll of the dice if you have a good one , some people have great luck with them ( and its luck ) , best one i've seen has 10 years use in circle tracking , left a 2 bolt main and had straps put on the caps , his philosophy was , if its limber , don't make a stress point with splayed caps , which in this case , seems to be working ,, its not a high rpm engine , they turn this one 6200
don't make a stress point with splayed caps Could please explain where the streess point is.
I think splayed caps are the way to go as they tie the pan rails in with the webbing which makes for a much stronger lower end.
I wish I could base all my info on one block that went for 10 years LOL
levisnteeshirt wrote:CNC BLOCKS wrote:levisnteeshirt wrote:^^^^ so true ,, its a roll of the dice if you have a good one , some people have great luck with them ( and its luck ) , best one i've seen has 10 years use in circle tracking , left a 2 bolt main and had straps put on the caps , his philosophy was , if its limber , don't make a stress point with splayed caps , which in this case , seems to be working ,, its not a high rpm engine , they turn this one 6200
well , it seems to be working , only 400 block i've ever heard of being ran for 10 years or better , he will fix a 400 block with splayed caps for a higher HP type of motor thats for a stock block class , but in about 2 years its cracking in the main web , and any where else one might crack ,
there is one 400 block that runs at the track I tech , its been running above 5 years , factory 4 bolt block , 625 hp motor , I say thats luck , no cracks , it was refreshed last year , looked great inside , for how much longer ?? who knows , it was running last night , finished 3rd ,
could you please explain why you constantly try to take what somebody posts , and try yo insult them , thats what i want to know , and if you are so good , why aren't you in Charlotte working for a nascar team ?? my friends shop that i refer to , was approached by Richard Childress to come and work for him , because of everything he had heard about him , so , put that in your smartass pipe and smoke it
[ could you please explain why you constantly try to take what somebody posts , and try yo insult them , thats what i want to know , and if you are so good , why aren't you in Charlotte working for a nascar team ?? my friends shop that i refer to , was approached by Richard Childress to come and work for him , because of everything he had heard about him , so , put that in your smartass pipe and smoke it/b]
blue88 wrote:So.. from what I am hearing.... pretty much all stock 400 stuff is time bomb.. I guess I will take my chances.. since motor cost me all of 0 and what the heck else I going to do with it.. collect dust on floor? Time to throw cam and some heads on it.. and spinner til she pukes.
blue88 wrote:I had no intentions of building a full out race motor with this combo. I don't have the money or time. I understand I cannot zing this thing above 6000 on a regular basis.. or I will have a mess and a boat anchor. My original question was.. how much would you turn it.. rpm.. with good rod bolts and basically stock components. My thoughts were... I would I be safe with 5500. I guess time will tell.. since it is going run or blown up this summer. Thanks again.
Wolfplace wrote:
Thing is at that point you can buy brand new Scat bushed & floated rods for not much more so why not go to a 5.7 or 6" one which gets some weight out of the piston?
That & any decent forged piston & a good balance job,, you should have a pretty fair piece without killing your bank account
blue88 wrote:Ok... so what is it going to cost for the aftermarket assembly that has been suggested???? Who sells the rotating assembly? Scummit? Jags? Competition products?
Users browsing this forum: Google [Bot], Greens Nice, Gregmo, lorax, numboltz, Yahoo [Bot] and 17 guests
