If so, maybe you can fine tune the duration of the spark versus the spark "range" via plug gap;
BrazilianZ28Camaro wrote:Wouldn't the greater gap reduce the spark duration per cycle?
dieselgeek wrote:BrazilianZ28Camaro wrote:Wouldn't the greater gap reduce the spark duration per cycle?
CDI sparks are *very* short duration compared to an inductive ignition. (I prefer inductive, especially in forced induction applications - and eliminating the distributor altogether).
MadBill, you're an engineer, would you expect the increased ignition voltage requirements of a bigger gap to cause more drag from the alternator? (in an application that uses one, that is).
Users browsing this forum: 2seater, 351crules, 66Vette, camaro itb, GARY C, mike hohnstein, SKeown, TTXPC, zums and 28 guests
