Intake valve guide wear problem
Re: Intake valve guide wear problem
Postby SilverXJ » Tue May 08, 2012 3:38 pm
Brian B wrote:intake (left) wear pattern looks like the roller is riding on the one side..
which tells me that the rocker stud is not square to stem/tip...
Looks like it.
exhaust (right) looking at the tip of valve sure looks to me like you have a
valve control issue. Looks like the valve is rotating looks like 3-4 wear patterns
from the roller?
I don't recall if the exhaust tips were cleaned up when reinstalled or not, so you could just be seeing different patterns.
SilverXJ
Postby robert1 » Tue May 08, 2012 4:30 pm
As long as you have stud mounted rockers you will have contact patterns like you show. There is nothing that you can do to stop it short of having the lifter, valve guide, and rocker stud all having the same centerline which is not going to happen.
robert1
Postby BrazilianZ28Camaro » Tue May 08, 2012 4:51 pm
Hello Silver, sorry to hear you are having problems again..
This topic I started some weeks ago may be helpfull:
viewtopic.php?f=1&t=30452
A little about Ayrton Senna - The Last Brazilian Hero
http://www.youtube.com/watch?v=4oLSYSJO5Ik&feature=context-vrec
BrazilianZ28Camaro
Postby BrazilianZ28Camaro » Tue May 08, 2012 4:55 pm
I'm wondering right now, wouldn't the exaust pressure (on muffled cars) blow the oil off the exaust guides ?
:roll: :|
BrazilianZ28Camaro
Postby donc » Tue May 08, 2012 5:01 pm
Ive seen the intake liners wear quickly from an over rich fuel condition, particulary the plain non spiral ones.
donc
Postby SilverXJ » Tue May 08, 2012 6:20 pm
robert1 wrote:As long as you have stud mounted rockers you will have contact patterns like you show.
They are pedestal mounted rockers.
BrazilianZ28Camaro wrote:I'm wondering right now, wouldn't the exaust pressure (on muffled cars) blow the oil off the exaust guides ?
Exhaust pressure would keep the oil out of the exhaust guide possibly while the intake vacuum would suck oil into the intake guide. I also remember reading your thread when I first found this. MotioMachine found no evidence of oil starvation and he installed spring locators when he did this head 4000 miles ago.
donc wrote:Ive seen the intake liners wear quickly from an over rich fuel condition, particulary the plain non spiral ones.
The AFR was around 14.7:1 in closed loop and went down to 12:1 at WOT in open loop. I hadn't finished fine tuning the WOT curve though, but it lived mostly in closed loop.
SilverXJ
Postby DaveMcLain » Tue May 08, 2012 6:40 pm
Somebody didn't cut the guides way down super short did they? I had some big Chevy heads come in one time where someone had cut the top of the guide down so that a PC seal sat down against the spring seat and on the other end they had ported/cut the guide much shorter too. Needless to say they had very little run time yet they were killed.
DaveMcLain
Postby SilverXJ » Tue May 08, 2012 7:30 pm
Nope, the stock guides are intact, well at least the outside.
SilverXJ
Postby Bos's5.0 » Tue May 08, 2012 9:32 pm
I only did a quick scan, but what are the chances the particular rocker tips haven't been hardened or not hardened enough, which in turn created excess galling and grabbing ? Like sand paper on the tip of your rocker.
Many people don't like Harland Sharp rockers. Just a guess, don't hold me to it.
Bos's5.0
Postby ICEMAN » Wed May 09, 2012 12:20 am
Galling comes pressures that exceed oil film protection, or from just plain inadequate oil supply. Have you observed oil flow to top end with engine running? Any restriction in place?
ICEMAN
Postby Kevin Johnson » Wed May 09, 2012 12:30 am
Is this a 4.6 stroker? Even with a 4.0 I suspect Mopar's strengthening of the block led to energy being transmitted to the camshaft.
Kevin Johnson
Postby SilverXJ » Wed May 09, 2012 6:33 am
Bos's5.0 wrote:I only did a quick scan, but what are the chances the particular rocker tips haven't been hardened or not hardened enough, which in turn created excess galling and grabbing ? Like sand paper on the tip of your rocker.
Maybe, but I don't think the stock rockers are hardened, are they?
ICEMAN wrote:Galling comes pressures that exceed oil film protection, or from just plain inadequate oil supply. Have you observed oil flow to top end with engine running? Any restriction in place?
I have and there is adequate oil flow. I have no real way to measure it though.
Kevin Johnson wrote:Is this a 4.6 stroker? Even with a 4.0 I suspect Mopar's strengthening of the block led to energy being transmitted to the camshaft.
It is a 4.6L stroker, but not a Mopar unit. But, what do you mean?
SilverXJ
Postby SilverXJ » Thu May 10, 2012 10:34 am
Randy @ Harland Sharp just finished repairing the rockers. He didn't think it was an oil starvation issue as every he didn't see anything else that would indicate that and the rockers were well oiled. He said the rest of the rockers were like new. He was surprised at the wear and though it could possibly have been a material incompatibility or maybe the intake valves were binding in the guide. He also suggested using lash caps, but I am unsure if we are going to use the same intake valves again.
SilverXJ
Postby SilverXJ » Tue May 15, 2012 6:43 pm
Had an oil analysis done. Only thing unusual were the silicon and copper levels. Copper from the valve guides and silicone from the valve guides and possibly when I pulled the timing cover and oil pan off 200 miles ago and resealed with RTV. No gas contamination.
SilverXJ
Postby BrazilianZ28Camaro » Tue May 15, 2012 7:28 pm
And how about the valves Silver?
They showed some signs of overheating?
BrazilianZ28Camaro
PreviousNext
Return to Engine Tech
Who is online
Users browsing this forum: 5speed1966, Bing [Bot], Coloradoracer, Cubic_Cleveland, jbusch, jeff8407, Mike Rogers, nevdos, rfast racing, riv187, Ted Gerstenslager and 35 guests
