by Brian W » Sun Apr 29, 2012 10:49 am
Make sure you check the CC's of each chamber. I have seen them off by 2cc'c on the same out of the box head. 0.0055 per CC is the removal rate on the IMCA spec head. If they are off you can usually angle the head slightly from end to end (#1 to #7 cyl) to correct the chamber size. Also, and I'm sure you already know this but the shape of the valves you choose can vary greatly the CC of the chamber.
