Grumpy's old pro stock small blocks, hp
Postby rustang » Thu Apr 19, 2012 11:37 am
I was reading an old article on Grumpy's old pro stock motors circa 1972. HP claimed was 600hp with 331cuin. I was curious what heads were used. Would these have been double humps or some angle plug deal? What kind of rpm did they twist these things to and what kind of tricks were used?
I've seen old Pro Stock AMC heads that they would cut in half and weld one on top of the other, etc. (Wally Booth?) Would the SBC's have been that extensive?
rustang
Re: Grumpy's old pro stock small blocks, hp
Postby Stan Weiss » Thu Apr 19, 2012 11:52 am
To be accurate the AMC heads were not cut in half. It took 4 heads to make 2 good heads. One head was cut so the bottom part was larger than the top while the other was cut so the top part was larger than the bottom. The 2 larger pieces were welded together to made the new taller head.
Stan
Stan Weiss / World Wide Enterprises
http://www.erols.com/srweiss/index.html
Stan Weiss
Postby DaveMcLain » Thu Apr 19, 2012 12:34 pm
Check out Grumpy's old book on the Chevrolet Racing Engine it has a lot of information on those engines and it's still an excellent read. Heads were 292 castings with VERY EXTENSIVE modification especially to the intake side. What's cool is also how many of the parts in the engine are regular production pieces. They were running the engine about 10,000 rpm.
DaveMcLain
Postby PackardV8 » Thu Apr 19, 2012 2:42 pm
I was there in the day and washed parts and pinned the rocker studs for many a short track SBC. Often the roller cam, lifters and valve springs were the only aftermarket internal parts. Still, having gotten used to aftermarket parts, I am continually amazed when I take apart a vintage race engine and see all those spindly stock SBC pieces in there. The Chevrolet engineers were tasked with building the lowest-priced OHV8 and given the directive to use as little iron, steel and aluminum as possible. When they were done, a ready-to-install engine cost Chevrolet about $55 to make. That it came to handle horsepower and RPM incredibly well was a happy accident.
We get used to seeing all the beefy aftermarket parts, but most are just for insurance and longevity. The stock parts would make horsepower for a while.
Speaking of round track, in the early days at Daytona, engine failures were the norm. Oils weren't that good and nobody knew about oil coolers. I've seen races where half the field dropped out with engine failures. None of the stock stuff was ready for 500 miles at full throttle and 6,000 RPMs. Pontiac was the first to figure out how to keep engines together around 1960 and they won most of the banked tracks.
Today, at 9,500 RPMS, failures are so rare, the whole engine program shop team would commit seppuku if they have an engine blow. But there's not a stock part anywhere on the car.
jack vines
Postby andyf » Thu Apr 19, 2012 3:19 pm
Pick up a copy of Grumpy's book, it is a classic. He shows all the tricks they used on those heads. They spent a lot of time eating cast iron dust to make those cars fly.
Andy F.
AR Engineering
andyf
Postby BrazilianZ28Camaro » Thu Apr 19, 2012 3:34 pm
rustang wrote:I was reading an old article on Grumpy's old pro stock motors circa 1972. HP claimed was 600hp with 331cuin.
According this guys , the power is a bit higher.
http://www.carcraft.com/techarticles/cc ... index.html
Only 680 HP @ 9000. :shock:
=D>
A little about Ayrton Senna - The Last Brazilian Hero
http://www.youtube.com/watch?v=4oLSYSJO5Ik&feature=context-vrec
BrazilianZ28Camaro
Postby DaveMcLain » Thu Apr 19, 2012 3:48 pm
I went to a thing at the PRI show one year honoring the 40th anniversary of the Small block Chevy engine and I got to meet Jenkins, Yunick, Duntov and others who were involved with the design, development and racing of the engine and it was fascinating. I think that for the most part the original design engineers were amazed at how well their compromises with materials, strength, packaging etc worked out over the years. After all they never imagined or intended the engine to become the most modified engine ever!
I don't think that the car in that story is the real Vega. That car disappeared at the truck stop across from the drag strip in East St Louis.
DaveMcLain
Postby bigjoe1 » Thu Apr 19, 2012 3:50 pm
I saw Jenkins 331 on the dyno at E#delbrock, and it made 665 HP at 8400 RPM
JOE SHERMAN RACINGENGINES
bigjoe1
Show Guest
Show Guest
Postby rally » Thu Apr 19, 2012 3:57 pm
It amazing how the stock Chevy parts hold up under those RPM conditions back in those days. And i am old school Chevy drag racer, i built a BB drag race motor with Chevy factory pieces and never had a failure. Same with rods, good conditioning with a shot peen, mag, and good bolts i never lost a factory rod.
rally
Postby SKeown » Thu Apr 19, 2012 4:06 pm
I had a dragster that turned 8K with "pink" rods and stock rockers.
SKeown
SKeown
Postby avengerengines » Thu Apr 19, 2012 4:13 pm
bigjoe1 wrote:I saw Jenkins 331 on the dyno at E#delbrock, and it made 665 HP at 8400 RPM
I messed with some modified production back then. We struggled to get near 500 hp with a 331. I said near 500. :mrgreen:
avengerengines
Postby ClassicComp » Thu Apr 19, 2012 4:25 pm
Seppuku!!! [-X Jack cars arent your only hobby are they????????
results speak for themselves
BobF
ClassicComp
Postby zums » Thu Apr 19, 2012 7:26 pm
the only thing close to "stock " on jenkins small blocks were the blocks and cranks, i use stock very loosely
zums
Postby rookie » Thu Apr 19, 2012 8:48 pm
zums wrote:the only thing close to "stock " on jenkins small blocks were the blocks and cranks, i use stock very loosely
Aluminum rods?
Has Anything You've Done Made Your Life Better?
rookie
Postby MrBo » Thu Apr 19, 2012 8:54 pm
How about that nylon tooth timing gear and silent chain? :)
MrBo
Next
Return to Engine Tech
Who is online
Users browsing this forum: 1989TransAm, ap72, Bing [Bot], cknight, colebalster, hrobins, kirkwoodken, lorax, maxracesoftware, plovett, pmann, robert1 and 15 guests
