184 Bow-Tie Block Questions
Postby cspeier » Thu Apr 12, 2012 8:31 am
I have a question on the 184 block. I have a new one here and going to use it for my build. The block is not priority oiling block. So this leads me to restricting oil and plugging holes. Would you guys just use a .060 restrictor in the back of the block and plug all the rest in front and what is remaining in the rear?
Or any tricks a guy should do to help oiling or prevent failure??
cspeier
Re: 184 Bow-Tie Block Questions
Postby Brian B » Thu Apr 12, 2012 10:56 am
Chad
Wet or Dry sump?
Brian B
Dakota Parts Warehouse
The Ferrea Valve Guy
Stocking HYLOMAR
Ask about our Fast Setting Silicone..its fast
Now in stock
5/16 hollow stems
5/16 6000 series SBC
877 235 2832
Brian B
Postby cspeier » Thu Apr 12, 2012 11:01 am
wet, with a Charlie's kick out oil pan. Drag race application.
cspeier
Postby monte442 » Thu Apr 12, 2012 4:46 pm
I prefer to drill the restrictors to a .090 hole instead of the .060,a good standard volume pump is all you should need,the Melling Select stuff seems to be pretty good. CVR also has some pumps that are a nice casting or they have them in billet also.
Mountain Lion Motorsports
Bethel, CT
monte442
Postby governor » Thu Apr 12, 2012 8:35 pm
Sell it and get an SHP block, prioroity oiling a big plus, a great investment.
Gov
a passion for racing
governor
Postby CNC BLOCKS » Thu Apr 12, 2012 9:28 pm
cspeier wrote:I have a question on the 184 block. I have a new one here and going to use it for my build. The block is not priority oiling block. So this leads me to restricting oil and plugging holes. Would you guys just use a .060 restrictor in the back of the block and plug all the rest in front and what is remaining in the rear?
Most Roller lifters are restricted to begin with and I would not restrict oil to them.
I have sold alot of SHP and SHP PRO blocks and Little-M's over the years and none have been restricted so far and no issues.
http://WWW.CNCBLOCKSNE.COM
IS A DIVISION OF
HINKSON AUTOMOTIVE
RESEARCH & DEVELOPMENT
We are WD on AFR, Dart, Wiseco, JE, CP, Crower, Manley, CARRILLO, Callies, King's Crankshaft. COMP CAMS, Diamond pistons ETC.
CARL HINKSON 207-892-7215
CNC BLOCKS
Postby airflowdevelop » Thu Apr 12, 2012 11:09 pm
no doubt...let it eat Chad...
airflowdevelop
Postby needforspeed66gt » Thu Apr 12, 2012 11:32 pm
I don't use them and the valve train parts are much happier on my motors than the ones I tear down that have restrictors in place, and there's no detriment to the bottom end oiling.
Nate
Engine Machinist
needforspeed66gt
Postby Adger Smith » Thu Apr 12, 2012 11:35 pm
Chad,
Don't restrict. Lifter & spring life usually suffer if you do. Make sure the front to back factory drill lines up on the main oil galley. I have redrilled them bigger, when I had to....
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
www.adgersperf.com Web site (view only)
Adger Smith
Return to Engine Tech
Who is online
Users browsing this forum: 4sfed, Bing [Bot], Coloradoracer, FuelieNova, Google [Bot], governor, jason snyder, jmarkaudio, KRYPTINITE RACE ENGINES, LJW, mallow415, rickyracer, Warpspeed and 27 guests
