sbc Head gasket
sbc Head gasket
Postby trh81 » Mon Apr 02, 2012 8:38 pm
Which Head gasket is best for a dart SHP block? Felpro 1003,or 1034? 4.125 bore Brodix al heads.
trh81
Re: sbc Head gasket
Postby CNC BLOCKS » Mon Apr 02, 2012 9:00 pm
trh81 wrote:Which Head gasket is best for a dart SHP block? Felpro 1003,or 1034? 4.125 bore Brodix al heads.
Where its only a 4.125 bore I would go with 1003 gasket!!
http://WWW.CNCBLOCKSNE.COM
IS A DIVISION OF
HINKSON AUTOMOTIVE
RESEARCH & DEVELOPMENT
We are WD on AFR, Dart, Wiseco, JE, CP, Crower, Manley, CARRILLO, Callies, King's Crankshaft. COMP CAMS, Diamond pistons ETC.
CARL HINKSON 207-892-7215
CNC BLOCKS
Re: sbc Head gasket
Postby trh81 » Mon Apr 02, 2012 9:29 pm
Thats what I was leaning towards thanks alot for the reply.
trh81
Re: sbc Head gasket
Postby rustbucket79 » Tue Apr 03, 2012 1:08 am
More often than not, especially when it comes to aftermarket heads, the heads determine the gasket size moreso than the bore diameter. Make sure to set the gasket on the head, and make sure there is no overhang of the gasket into the chamber. Naturally, the same thing applies to the bores. The fire ring must be compressed on both sides for it to work.
rustbucket79
Re: sbc Head gasket
Postby CNC BLOCKS » Tue Apr 03, 2012 2:45 am
I would think the 1003 would work its 4.166 bore gasket.
IS A DIVISION OF
HINKSON AUTOMOTIVE
CNC BLOCKS
Re: sbc Head gasket
Postby RTR-1 » Tue Apr 03, 2012 3:59 am
Since you are using aluminum heads, I would use a multi-layer gasket. They don't seem to brinell or indent the deck surfaces of the heads as bad caused by the wire rings in the 1003's or 1034's. Especially between cylinders 3 & 5, 4 & 6. Unless you don't plan to take this engine apart and see the dents, those 1003's or 1034's will not give you problems.
RTR-1
Re: sbc Head gasket
Postby robert1 » Tue Apr 03, 2012 8:11 am
RTR-1 wrote:Since you are using aluminum heads, I would use a multi-layer gasket. They don't seem to brinell or indent the deck surfaces of the heads as bad caused by the wire rings in the 1003's or 1034's. Especially between cylinders 3 & 5, 4 & 6. Unless you don't plan to take this engine apart and see the dents, those 1003's or 1034's will not give you problems.
X2
I would only use MLS for aluminum heads. They may cost a little more but every time you pull the heads with a 1003 you'll need to resurface them.
robert1
Re: sbc Head gasket
Postby trh81 » Tue Apr 03, 2012 9:57 am
Which MSL gasket? Cometic or Felpro?
trh81
Re: sbc Head gasket
Postby trh81 » Tue Apr 03, 2012 3:19 pm
Looks like felpro Q1143 4.165 bore or cometic C5401-040 4.135 bore?
trh81
Re: sbc Head gasket
Postby The Engineer » Tue Apr 03, 2012 3:29 pm
I've had very good performance from the FelPro 1143 MLS head gaskets!
The Engineer
Re: sbc Head gasket
Postby af2 » Tue Apr 03, 2012 4:11 pm
The Engineer wrote:I've had very good performance from the FelPro 1143 MLS head gaskets!
X2 I have had mine off 3 times in 6 years and just clean and re-install. Never a leak.
GURU is only a name.
af2
Re: sbc Head gasket
Postby trh81 » Tue Apr 03, 2012 6:15 pm
Felpro 1143 it is then. These are brand new heads so I want to protect them as best I can.
trh81
Return to Engine Tech
Who is online
Users browsing this forum: Adger Smith, ap72, Bing [Bot], Google [Bot], hoffman900, Jens.J, POS Dakota and 33 guests
