BBF morel Hyd. Roller lifters
Postby CREngines » Mon Mar 26, 2012 8:16 am
I have a set of brand new set of Hyd. roller lifters here for a big block 385 series ford. They are supposed to be morels, and the better lifter that is improved and and capable of 6500ish with out floating or collapse. i have a suspicion they may not be boxed correctly they look an awful lot like the cheaper lifters out there. they have a full body, 700 wheel, a regular snapring and about .250 of travel. is there anyway to tell if i have the better lifter? i need these to hold against 440 open and turn 6500 rpm without collapsing or floating. can somebody help me out?
WD For Lucas Oil, Ferrea Valve, Callies, Racetec Pistons, VP Racing Fuel, and HVH Cylinder Heads.
CREngines
Re: BBF morel Hyd. Roller lifters
Postby PFC1 » Mon Mar 26, 2012 8:27 am
Here is a link to Morel's website but, you'll likely have to contact one of the dealers, have them have John contact you, he does not list a phone number. He has however been very helpful to me in the past when he's called me. Hope this helps.
http://johncalliesinc.com/morel_products.php
Bret
The heart of the wise inclines to the right, but the heart of the fool to the left. Ecclesiastes 10:2
PFC1
Postby CREngines » Mon Mar 26, 2012 11:48 am
thanks for the link to that website, thats good for reference. im sort of already waiting on an answer from that avenue however.
CREngines
Postby CREngines » Mon Mar 26, 2012 1:03 pm
got my answer. John called me. 8)
CREngines
Postby 91stang » Tue Mar 27, 2012 8:38 pm
So whatcha got? And any more info on the build?
1991 mustang 3040 with driver all motor all the time 9.70 @ 138.75 1.31 60' street driven mufflers and real tires, mt 275/60/15 radials with a 950hp holley.
91stang
Postby CREngines » Tue Mar 27, 2012 11:14 pm
They are the basic hydraulic roller lifter that morel makes for a 385 series ford. They are good for about 6k and 390 open. They are working on an improved version based on the Chevy lifter that has done really well but its not available for another month roughly. Lunati lists it in their new catalog but it is not available yet. Because this motor has to beout the door before then I'm going ahead with the build and we are going to try them.
Its a 520 inch Na low rpm motor that is used in a near full size monster truck for mudbog competitions. Its built conservatively to maximize longevity. 241/249 .639 lift cam, 11.5 cr, ford racing Scj heads and a weiand stealth. Hoping to dyno it this week. This motor gets put in a mudpit and held wide open for minutes at a time like a marine motor every weekend.
CREngines
Return to Engine Tech
Who is online
Users browsing this forum: amc fan, Bing [Bot], dcl, Sandman, Stef, utmost and 18 guests
