Belgian1979 wrote:I have just set my roller cam end play : .006".
What do most here use as end play ?
I noticed that the cam gear is not perfectly aligned with the crank sprocket. It sits more than .005" back. The sprocket doesn't seem to move further back anymore. Does this need to be solved and if so how ?
Belgian1979 wrote:Wouldn't it be easier to shim the camgear ? If so, where can those shims be had ?
Cedarmachine wrote:Belgian1979 wrote:Wouldn't it be easier to shim the camgear ? If so, where can those shims be had ?
Of your cam has a Torrington bearing on it, I wouldnt put some thin shim behind it, it would be a bit flimsy..
If it were a regular gear, you could machine it to accept a roller bearing and adjust the depth you machine it accordingly..which is more work than just machining the lower gear.
I could do it in less than 10 minutes..why mess with shims?
If you have an aluminum front cover, I'd use a plastic or fiber tipped thrust bumper. I see those roller ones tear the hell out of the aluminum sometimes. I have an ATI aluminum one in here right now that I'm going to have to weld back up and machine from wear. Sometimes they are fine, other times not. The plastic ones are always fine.
Belgian1979 wrote:Cedarmachine wrote:Belgian1979 wrote:Wouldn't it be easier to shim the camgear ? If so, where can those shims be had ?
Yes it's a upper gear with torrington.
So the machining is half the diference right ? How much camfer ?
As for the timing cover problem : I understand that one. Was thinking of putting a steel washer on the back of the cover. Actually I like the rollerized ones. It came with the comp cam cover. Makes me wonder why the use it if it eats the covers. Well...
zums wrote:i think his concern is how to machine the chamfer if its interfering
Wolfplace wrote:Or just put it in a lathe & cut both surfaces,,,,,,,,,,
Users browsing this forum: Bing [Bot], jsgarage, Lakki, lorax, vode131 and 9 guests
