What is the bes 76 cc chamber GM head?
Postby MidgetMotorsports07 » Fri Mar 09, 2012 4:15 pm
We build quite a few engines that require a stock casting head. I usually use 441, 487, or 487X
those 3 are getting harder to find every year. I know the 993 casting is ok but they are pretty crack prone in my experience. 882's are plentiful, but I have heard the debate go both ways on how well they flow. I was just wondering if anyone has actually put these on a flow bench and tested them?
MidgetMotorsports07
Re: What is the bes 76 cc chamber GM head?
Postby billet » Fri Mar 09, 2012 4:24 pm
Check out Stan Weiss's site he list flows on several heads some stock some ported.
Link: http://users.erols.com/srweiss/tablehdc.htm
billet
Postby john@bmp » Fri Mar 09, 2012 4:27 pm
Don't buy a head based solely on flow.
john@bmp
Postby MidgetMotorsports07 » Fri Mar 09, 2012 4:50 pm
john@bmp wrote:Don't buy a head based solely on flow.
I am not really concerned with peak flow numbers, I am fairly certain that after about .480 lift you aren't really going go gain anythin. The combustion chambers are very similar and the plug location didnt really change. I was really just wondering if the 882s are worth trying. I understand what you are saying though.
MidgetMotorsports07
Postby MidgetMotorsports07 » Fri Mar 09, 2012 4:51 pm
billet wrote:Check out Stan Weiss's site he list flows on several heads some stock some ported.
Thanks! I will check it out.
MidgetMotorsports07
Postby the nitro man » Fri Mar 09, 2012 5:39 pm
441, 487 & 993 are all decent heads, but the 487x is the better head.
thanks, jerry
the nitro man
Postby MidgetMotorsports07 » Fri Mar 09, 2012 7:58 pm
the nitro man wrote:441, 487 & 993 are all decent heads, but the 487x is the better head.
yes they are... but getting scarce! I have 3 sets left, but I have countless 882s
MidgetMotorsports07
Postby ProPower engines » Fri Mar 09, 2012 11:43 pm
there is no comparison between the others and the 882's for power. They just suck period and are thin castings as well.
I have found water by just cutting for a 1.6 exhaust with out trying to install hard seats.
Same deal going to a 2.02 valve as well
ProPower engines
Postby MidgetMotorsports07 » Sat Mar 10, 2012 12:05 am
Thanks for the info, i will remember to just use them for paper weights like i do now.
MidgetMotorsports07
Postby JoePorting » Fri Mar 16, 2012 2:13 am
Meaning??? World Products heads flow like dog poo. Buy them not because they don't flow, but because they'll crack, cause your motor to blow, and force you to walk home. Bill Mitchell says we all need to walk more.
Joe Facciano
joefacc1@yahoo.com
JoePorting
Postby mag2555 » Fri Mar 16, 2012 6:06 am
If you have all those 882 castings cryoed they will hold up to 500 hp and should last 2 seasons.
Its imperative that all the sharp edges on the deck surface( water, bolt holes and all) be rolled over!
mag2555
Postby MidgetMotorsports07 » Fri Mar 16, 2012 7:56 am
mag2555 wrote:If you have all those 882 castings cryoed they will hold up to 500 hp and should last 2 seasons.
I'm sure i can get away with running them if needed, but getting them to hold up when I cut the valves out and put seats in them is the problem.
MidgetMotorsports07
Postby johnretired » Fri Mar 16, 2012 11:28 am
My opinion is to stay away from the 882.
Stock for stock, I swapped the 882's for 487 casting on a L82-77 vette.
Car picked up 10-15 mph in the quarter mile and several mpg.
niether heads has 2.02 valves.
Let the vette restorers have the low po stuff.
489 chevy
johnretired
Return to Engine Tech
Who is online
Users browsing this forum: bgr, Bing [Bot], Google [Bot], icd, Majestic-12 [Bot], Yahoo [Bot] and 14 guests
