cam rpm range and cubic inch
CGT
Re: cam rpm range and cubic inch
Post by CGT »
500 inch drce3 headed engines making peak power at 9700 with 275 duration. 290 inch stock headed engines making peak power at 7500 with 282 duration and the cam dictates rpm?
CamKing
Post by CamKing »
CGT wrote: and the cam dictates rpm?
Yes, when there are no other restrictions.
When you have a big enough port, exhaust, intake, and carb, the cam duration controls the peak HP rpm.
In fact, there is a direct mathematical relationship.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
CGT
Post by CGT »
So you can make the Prostock peak a couple thousand higher, or a few thousand lower?
CamKing
Post by CamKing »
I can easily make it peak a few thousand lower.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
CGT
Post by CGT »
And higher?
Rick360
Post by Rick360 »
CamKing wrote:
CGT wrote:So you can make the Prostock peak a couple thousand higher, or a few thousand lower?
How many less degrees of duration would that take to lower peak TQ by 2000 rpm and/or peak HP by 2000 rpm?
Rick
CamKing
Post by CamKing »
Rick
It depends on the Bore, Stroke, and Rod Length.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
BrazilianZ28Camaro
Post by BrazilianZ28Camaro »
:-k
I'm curious how the intake ram filling and the exaust max excavenge RPM relates to pk tq and pk hp ;
Some EMC engine power curves with three tq spikes in the curve with almost identical peak #s comes to mind.
Maybe there was more than one single part dictating the pk tq?
Just asking not trying to be smart. :wink:
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
plovett
Post by plovett »
I see engines make peak power at different rpms, with the same displacement and cam size, very frequently. No doubt if you keep all the other variables the same, then cam size has a direct relationship. It's not even in doubt in my opinion. My street 432 cid engine peaked at 6200 rpm with a 240/246 @ 0.050" solid flat tappet cam.
JMO,
paulie
Rick360
Post by Rick360 »
CamKing wrote:
Rick
Let's pretend I know it is this ...
Bore = 4.700"
Stroke=3.600"
Rod=6.000"
Rick
randy331
Post by randy331 »
"Resrtiction" is kind of a relative term. All engines are restricted to their current power level and rpm by something.
So if the induction tract is sized for 9500 rpm, and the cam won't let the engine make peak power there, isn't the CAM the restriction?
I guess it would be true to say IF you have a big enough CAM, exhaust, and carb, the induction size sets the rpm.
Randy
Orr89rocz
Post by Orr89rocz »
That sounds true. Just look at long tube runner TPI sbc's. Very long intake tract and the cross sectional areas arent large enough to support alot of RPM on most 350+ inch motors. Seems any cam you throw in them even if the heads are large, they wont peak much past 5000 rpm if that. Most in the 4800 range. Hp may hang on for several hundred rpm without falling off but does not rise any more. Intake is the restriction. Now if you open up the base to large enough cross sections, and have a runner with tube diameter thats large enough to pass some serious airflow and also not be a cross sectional area limitation, you can pull alot more rpm. Also can take advantage of the intake ram tuning, as you will find the total runner length on some of those systems actually are tuned for 6000 rpm+.
So in that sense the cam would not control rpm range.
MrBo
Post by MrBo »
The camshaft is # 1 in the hierarchy in my book. Just look at some of the stock BBC’s from yesterday with the huge square port heads ….say a 1970 LS6.
Peak torque in the 3000’s rpms??…. Peak HP in the 5000’s rpms?? What is wrong with this picture?
Camshaft!
"I promise you Sheriff, I won't throw one more rock... Didn't say nothin' 'bout no brick!" --Ernest T Bass
Orr89rocz
Post by Orr89rocz »
Like said by Camking, if the intake and heads are large enough the cam will dictate. But you wont get a 170cc 1.94 valved stock iron sbc head on a 427" sbc to peak at 8000 rpm... I dont care what cam you put in there.
plovett
Post by plovett »
Yup, it's a huge oversimplification to say with this displacement motor and this size cam you will have this rpm range. Pretty much useless without more information.
JMO,
paulie
