In addition to my last post inquiring about more details of the SB results, I'm also curious how the BLP baseline carbs showed in comparison to the other entries in their respective classes.
Brad Hawk wrote:Sweet... what an event!![]()
dieselgeek wrote:Interesting observations, every N/A V8 I've tuned recently (using 8 O2s) has at least a 1.5-2.0 point spread in AFRs before we start trimming individual cylinders.
How about a carb-vs-EFI shootout in the future with these same (obviously very qualified) guys putting on the competition?
jmarkaudio wrote:dieselgeek wrote:Interesting observations, every N/A V8 I've tuned recently (using 8 O2s) has at least a 1.5-2.0 point spread in AFRs before we start trimming individual cylinders.
If you are injecting the same amount of fuel in every cylinder why would you have the AFR that far off unless each cylinder is not pulling near the same amount of air?
Especially on a sequential system, I might see that happening on a batch fire. I would not expect a N/A engine with a quality intake and a carb to stray even at most half a point, but I have seen it get really strange. I will say that seeing the difference between 2 collector O2's and 8 primaries is real eye opening.
If you are injecting the same amount of fuel in every cylinder why would you have the AFR that far off unless each cylinder is not pulling near the same amount of air? Especially on a sequential system, I might see that happening on a batch fire. I would not expect a N/A engine with a quality intake and a carb to stray even at most half a point, but I have seen it get really strange. I will say that seeing the difference between 2 collector O2's and 8 primaries is real eye opening.
razor66 wrote:jmarkaudio wrote:dieselgeek wrote:Interesting observations, every N/A V8 I've tuned recently (using 8 O2s) has at least a 1.5-2.0 point spread in AFRs before we start trimming individual cylinders.
Mark, what kind of differences did you see between the collector's O2 readings and those in the individual primaries? Thanks.
The small block only had O2 sensors in the collectors while the BB only had them in the primaries.
Users browsing this forum: No registered users and 0 guests
