PackardV8 wrote:A friend ( my boss ) insists that the flywheel HAS to be blanchard ground, and that doing it on the regular grinding table we have is a big NO-No....He could not tell my why it is a NO-No, just that it is.
In Blanchard grinding, a grinding wheel is placed on a vertical spindle and then moved counter to the rotation of a magnetic chuck, which holds the piece in place. The process leaves a telltale finish pattern on the surface of parts.
Not clear on what you mean by a regular grinding table - are you using a unidirectional surface grinding machine? If so, it isn't the best process and your boss may be correct. However, check any automotive machine shop which grinds flywheels every day and there's no true Blanchard grinder in sight. The processes are somewhat similar except the workpiece/flywheel is bolted down and the finish is essentially invisible. The advantage of an automotive machine is it registers the flywheel off the same center hole as mounted on the crankshaft and spins the flywheel in the same manner as it will be operating in the car.
checking flatness/runout on a granite table it is less than .001" total indicated across the entire flywheel.
Checking it on a surface plate isn't using the same registration. The flywheel is only located on the crankshaft by the small area around the bolt holes, which may or may not be precisely in the same plane as the full surface area of the back side. A properly ground flywheel will show essentially zero runout when rotated off the mounting surface.
Bottom line, you're probably OK, but your boss has a valid point.
jack vines
Thanks Jack- What I should have said when I mentioned checking it on the Granite table is, we used 1 -2 - 3 blocks under the flywheel bolt mounting surface holding the flywheel off the table. So we did register off the flange/bolt mount surfaces. And went around that with a dial indicator mount on a machined block and checked the actual flywheel surface all the way around about one inch in from the outside edge while the flywheel was sitting on the 1 2 3 blocks.
The grinding machine is just a flat table that holds the flywheel down by magnetism, and the grinding wheel moves back and forth automatically over the top. I have never paid much attention to the actual make and model as I am one of the shop electricians and service tech, not a machinist. Guess I could ask
We dressed the wheel first to insure it was true, and also did a light skim cut of .005" on the back of the flywheel first using the front as the register as it was flat as far as we could tell. so essentially we trued up the backside by using the front as a register, then cut the front face using the fresh cut back as a register for the front. As long as the original front surface was parallel to the mount flange I was hoping I would be OK.
That seemed to be proved out by sitting the flywheel flange mount surface on a couple of 1-2-3 blocks then running the dial indicator all around the front face. I know it wasn't the fastest method, but it was FREE, and seemed to check OK. I was asking about the blanchard grinder as it leaves a different finish verses what our surface grinder does. Was wondering if the disc would actually 'know' the difference after a couple of little "burnouts" ??
If life was easy I would be bored. My wife has assured me I will never be bored.
