400 SBC hi nickel identification
BrazilianZ28Camaro
Post by BrazilianZ28Camaro »
Hello friends
I just need some info about how to ID a hi-nickel 400ci factory block. :?:
I've been reading different advises, so I'm confused.
There's a code or sign in the block to look for?
Hope the knowledgeable members here can shed some light :D
Thanks in advance!
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
ProPower engines
Re: 400 SBC hi nickel identification
Post by ProPower engines »
From what I have seen the 509 block has the rectangle bars cast in the valley meaning higher nickel content in the casting.
The blocks I have machined have had a shinier finished machined appearance and were slightly harder to hone.
There may me others with more nickel but a basic rule to go by is the 400 blocks had way more nickel to make them stronger because of there design.
Jginger
Post by Jginger »
under the timing cover will be casting numbers cast in the block,
like 010 or 020 or both.
BrazilianZ28Camaro
Great info friends!
My 400ci #509 two bolt block have the rectangles in the lifter valley and "010" on the timing cover area.
Guess I'm lucky !!! :D :D
NEW BEST ET
