DaveMcLain wrote:Many 4412 packages are designed to close the power valve at high rpm. This is done to pull out fuel and keep the carburetor from getting too rich on top yet still have enough fuel to make proper torque at lower rpm. This happens because as the engine revs against the restriction of the carburetor manifold vacuum can increase to a fairly high value and higher than the rating of the power valve which most of the time is around a 4.5. This can help power in the last few hundred rpm of operation beyond peak but it doesn't have much of an effect at the horsepower peak itself which will happen at or around 6200rpm on a 350 inch engine.
mike pettit wrote:vdl fuel systems
Users browsing this forum: Bing [Bot], dat383, Dragsinger and 14 guests
