Filling exhaust cross over
Postby Doom86 » Fri Jan 07, 2011 4:48 pm
Is there any filler you can use that doesn't require melting pistons and cans to fill the exhaust cross over ports on a SBC head? I don't own or have access to a oxy/acetylene torch which is a shame because I do have cast iron skillets and pistons.
I've read of some block filler's working but not certain obviously.
Thanks!
Doom86
Re: Filling exhaust cross over
Postby 6sally6 » Sat Jan 08, 2011 12:00 am
How about stuff it full of Aluminum foil?! Simple is good.
6sally6
6sally6
Postby PackardV8 » Sat Jan 08, 2011 12:36 am
I just use a thin stainless steel plate on each side.
jack vines
Postby F1Fever » Sat Jan 08, 2011 3:56 am
jb putty in the intake cross over.
F1Fever
Postby CREngines » Sat Jan 08, 2011 4:48 am
rescor, castable alumina ceramic. buy it from mcmaster carr. works great but its expensive @ 90 bucks a box. a box would would probably do 10-15 heads.
WD For Lucas Oil, Ferrea Valve, Callies, Racetec Pistons, VP Racing Fuel, and HVH Cylinder Heads.
CREngines
Postby ZIGGY » Sat Jan 08, 2011 7:17 am
X2 on stainless plates.
ZIGGY
Postby F-BIRD'88 » Sat Jan 08, 2011 9:08 am
Some of the SBC smogger heads like the #4416 305HO heads have twin egr/exhaust riser passages on the center two exhaust ports.
So you want to fill them to stop the center exhaust ports from cross talking.
Has any one used Furnace cement? http://www.imperialgroup.ca/product.cfm?navcategory=5&category=16&product=366 Like this stuff. Will it stay in there?
What about using a furnace repair Firebrick Image trimmed to fit the passage as tightly as possible and cement it in there with furnace cement?
F-BIRD'88
Postby Matt Gruber » Sat Jan 08, 2011 10:06 am
a friend used plaster of paris.
i made a plug from scrap 1/4" thick steel, and filled in the gaps with a dab of muffler cement.
i think it should be plugged as close as possible to the valve as it has been shown that the passage really disrupts flow, like down 20hp. i don't think a long passage blocked at the end is as good as blocked close to the valve, but i admit i never tried to prove it with a test. might not make any difference.
learn how to tame a lumpy cam for the street, 14.5-18 mpg around town (was 11-14) with a fully divided dual plane, see my site:
http://community-2.webtv.net/mattgru/carb/
drive off cold 1200 rpm no stall
Matt Gruber
Postby F1Fever » Sat Jan 08, 2011 10:19 am
I haven't either but I know I've used jb putty or quick steel more times than I can count and have never had a problem.
F1Fever
Postby F-BIRD'88 » Sat Jan 08, 2011 10:31 am
F1Fever wrote:I haven't either but I know I've used jb putty or quick steel more times than I can count and have never had a problem.
JB Putty will withstand the heat in the exhaust port?
F-BIRD'88
Postby John R » Sat Jan 08, 2011 5:12 pm
X3 on the stainless plates.
Felpro makes intake gaskets with integral stainless steel heat cross over block off plates. Simple....
John R
Postby ZIGGY » Sat Jan 08, 2011 5:23 pm
I'd be interested in any hard information the head guru's may have on filling the passages completely vs. blocking with plates.
ZIGGY
Postby Doom86 » Sat Jan 08, 2011 6:41 pm
Thanks for the the info. I've read it steals a fair bit of power even more so at higher levels.
These are smogger #416 casting GM heads I'm working on.
Here's a photo of exactly what I'm talking about so there's no confusion. This was taken before the final blending of the sweeper cut in the bowl. My plans are to fill the cross over all the way to the exhaust bowl and blend it in. With the stainless plate idea are you wanting to weld it in the exhaust port or are we talking about different things?
Stuffing it full of aluminum foil isn't a bad idea. I guess the only problem then would be figuring out how to keep it in there and uniform in the exhaust port.
I was wanting to try block filler, some say it works great and with a gallon costing $15 it's very appealing.
F1Fever you used quick steel for this? Just wanted to make sure we're talking about the same "part" of the head I know some confuse it. I tested Quicksteel out just to see how it handled it's self under extreme heat and it get's hard as nails held over a flame, not brittle or flaky. But I don't know how it handles it's self over time, or adhears at those temps, ect.
Thanks again all
Doom86
Postby MadBill » Sat Jan 08, 2011 11:02 pm
There's water close by, so the wall there shouldn't get nearly as hot as when exhaust gas was flowing through the passage. (Consider that hi temp silicone cooks at many hundreds of degrees less than EGTs yet works fine on the header flange, as long as the gasket doesn't leak at all.)
"There's no product that can't be made cheaper and worse."
Postby F1Fever » Sun Jan 09, 2011 12:01 am
Thanks again all
yes, wrong part of the head, while the package claims "cylinder walls" I think the max temp is only around 500*f....
F1Fever
Next
Return to Engine Tech
Who is online
Users browsing this forum: turbodart and 21 guests
