Rear engine drag chassis
Postby brechlrl » Wed Sep 15, 2010 10:15 pm
My buddy built a hard tail rear engine dragster..150 inches wheelbase. The chassis is chrome moly, and he might have over built it a bit, so it is quite stiff. He is having trouble hooking up and experiencing wheel hop on launch. Could the chassis be too stiff?
brechlrl
Re: Rear engine drag chassis
Postby John Wallace » Thu Sep 16, 2010 11:50 am
I don't think you could be too stiff.
That's even shorter than my dragster. (180")
No suspension right?
What's the launch RPM?
Power Combo?
Slicks?
Mine hooks great and launchs good.
Also, what is the front to rear weight ratio?
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
John Wallace
Postby brechlrl » Thu Sep 16, 2010 1:38 pm
Tire is 10.5 x 31 Engine is 340 cube 435 horse. 3 speed automatic.3.70 gear Launch at 3500. No rear suspension, solid axle with torsion suspension in front. We are going to scale it to see where the weight distribution shakes out. What should it be?
brechlrl
Postby 582r10 » Sat Sep 18, 2010 12:31 pm
brechlrl wrote:My buddy built a hard tail rear engine dragster..150 inches wheelbase. The chassis is chrome moly, and he might have over built it a bit, so it is quite stiff. He is having trouble hooking up and experiencing wheel hop on launch. Could the chassis be too stiff?
First thing I would suspect is too much air in the rear tires.
Roger
582r10
582r10
Postby BillyShope » Sat Oct 02, 2010 7:29 am
brechlrl wrote:...solid axle with torsion suspension in front.
Use of a front suspension allows the chassis to be torsionally stiff and the wheelbase to be short. Good work! Keep the front wheel rate low. The early short wheelbase slingshots...such as the Mooneyes...would have had longer careers if they had included a front suspension.
If someone suggests a REAR suspension, pick up a tire iron and chase him away.
http://www.racetec.cc/shope
BillyShope
Postby BCLS776 » Sat Oct 02, 2010 8:10 am
Roger
582r10
Try somewhere around 6 to 8 psi in the tires. It should hook with that and you can finesse it from there.
Bryan
583 in 225" hardtail dragster
Northern Lights Raceway
BCLS776
Postby John Wallace » Sat Oct 02, 2010 10:04 am
Billy any suggestions on the design of the front suspension?
John Wallace
John Wallace
Postby BillyShope » Sat Oct 02, 2010 11:42 am
John Wallace wrote:Billy any suggestions on the design of the front suspension?
Nope. Well, if you have a clever way of increasing the wheel rate at the right front ONLY in rebound ONLY, it would be nice. The idea is to increase the weight pulled from the right front...so as to equalize rear tire loading...while maintaining equal spring rates during braking. Wait a minute! Wait a minute! This is a dragster, so you're using a chute. So, forget all that fancy stuff and simply use coil springs with a higher rate spring at the right front. There's a spreadsheet at my site to help in spring selection.
BillyShope
Return to Chassis / Suspension / Body
Who is online
Users browsing this forum: No registered users and 2 guests
