Making Smaller Wrist pin bushings for GM 6"rods
Has anyone tried to get pin bushings made with a small ID.
I want to use a GM 6" rod with a Honda journal size as a sudstitute for a Nissan 6.003 rod for use in an "L"-series 4 cylinder race application.
My thought is to machine the Nissan crank to Honda size and use a piston guided rod set up Because the big end is a bit narrower about .050" than the nissan rod thus keeping the rod centered over the oil holes.
The stock rods work and are sized correctly to fit the crank but real hard to find.
The hard part is to find a pin bushing that will fit say a scat rod with the
300zx wrist pin ID
That said I approached them about the pin bushing sizing and they are not willing to do it
If anyone has any ideas on who or where I could get them it will be a big help,
As the rod must be similar to a stock type rod in design but as a sort of spec rod Scat is easy to get here and cost effective if bought in sets they will service 2 engines.
Thanks again,
300zx wrist pin ID
Thanks again,
- needforspeed66gt
That's the place, PPPC = Precision Products Performance Centerzeronine wrote:There is a place called PPPC in NC that have got me out of trouble many times. They specialize in making these bushings. They may even have what you need on the shelf as blanks. You can call them on 1-800-421-9150, and ask for DJ.
Precision Products is in Arden N.C. 800-421-9150
www.pppcenter.com Bill
Hendrens Racing Engines
1310 U.S.Hwy 221 North
Rutherfordton North Carolina 28139
828-286-0780
828-286-0780
