Q16 VP fuel?
- Show Guest
VP Q-16 gas
I have had two other engine builders call me and say thet saw a 25 HP increase on a 700 HP engine. I have not tried it myself yet, but I intend to do so ASAP.
JOE SHERMAN RACING ENGINES
We have had same type of results on 3 different projects also in that 900-1000 hp range. Jet up 3-4 sizes and no adjustment to ign timing. 10-25 HP depending on specifics. It does seem like the more efficient the engines were the less we gained. Got 22-25 hp on a 1.75hp/ci but only 10-12 on a 2.3 hp/ci engine.
Since I run a blown gas deal I pay pretty close attention to available gas. The Q16 is oxygenated and in naturally aspirated engines you should see some power increases if jetting up about 5 to 6%. It also should take more timing in general, the added methanal increases the octain rating. In blown applications if your running an intercooler it also makes more power over VP's C16. But in non-intercooler applications you have to be careful because the distillination figures are lower than C16, meaning the fuels boils off at a lower temp. The very best gas for me is VP's Import. But it's pretty expensive...unless you really need it.
That's my experience any ..............blessings............Ron.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
John 14:6
Ron Clevenger
According to VP you need to jet up about 4-5% with this fuel. To the best of my calculations if you are currently running C14 with your jetting optimized, just by switching the fuel you will have jetted up by 2.8% due to specific gravity. My question is; do you need to jet up an additional 4-5% or only the extra 1.5-2%? Also on a twin dominator setup, how much is 4-5% or 1.5-2% roughly, 1-2 jet sizes? Just thinking outloud here.
Just dynoed with it tonight for the first time. 588 BBC with 385CFE heads,LSM 55mm cam 284-300 on 114, 920-880 lift. 14.9 to 1 CR. Best power with Track Tech 114 was 1068 at 7600rpm. Pro Systems 1300 with 96 jets, Sniper intake with 1" spacer. Purged the fuel system and put in the Q16 fuel with 98 jets and picked up over 20 horsepower. Never seen anything like this EVER. Moved timing to from 34 to 35 degrees, 101 jets and finished the day with 1101. There was no power increase with the timing and the conventional fuel.
James Baldwin
USA RACING ENGINES / THE WOP SHOP
713-645-4000
713-645-4000
Great power, I will be trying Q-16 in my 555 soon.usaracing wrote:Just dynoed with it tonight for the first time. 588 BBC with 385CFE heads,LSM 55mm cam 284-300 on 114, 920-880 lift. 14.9 to 1 CR. Best power with Track Tech 114 was 1068 at 7600rpm. Pro Systems 1300 with 96 jets, Sniper intake with 1" spacer. Purged the fuel system and put in the Q16 fuel with 98 jets and picked up over 20 horsepower. Never seen anything like this EVER. Moved timing to from 34 to 35 degrees, 101 jets and finished the day with 1101. There was no power increase with the timing and the conventional fuel.
Was the Sniper worked over or just a gasket match ?
I too have been looking at the Q-16. Once I get to the track and do some runs with the ole C-16 then the switch will be on. Wow that 33 hp in just fuel. Thats awsome, that 588 makes some steam...
You can fix broke...... But you cant fix stupid
Never Under Estimate the Power of Stupidity
http://www.youtube.com/watch?v=7xTl5cytNEw
