Dominator Project
Post photos/videos of anything* you own - Or, ask to see something.
Bad78Cutlass
Dominator Project
Post by Bad78Cutlass » Sat Oct 04, 2014 7:25 pm
I am converting a gas #7320 (2" butterfly x 1.81" venturi) Dominator over to E85, with Mr Whitener's help...And getting a few parts through him as well. This is the older style body, but it's different and you never see them being used anymore. Figured my brother and I would change that!
So far we have drilled and tapped for 8/32 removable air bleeds and removed the old vent tubes. Then we deburred and polished the venturi's. Later I am going to drill/tap for t-slot restrictors...this coming week I will order the BLP metering blocks and 18 hole boosters for it. Maybe next weekend will have it on the motor ready to fire up.
Compton Bros. 408 SBC on E85 - 10.07 @ 131 - 6.36 @ 107 All motor ~ 3190lb
Bad78Cutlass
Re: Dominator Project
Post by Bad78Cutlass » Sat Oct 04, 2014 7:30 pm
Before
Bad78Cutlass
After
Bad78Cutlass
Post by Bad78Cutlass » Sun Oct 05, 2014 8:58 pm
T-slot restrictors in now. Pictured are just blanks...Going to order the air bleeds and restrictors tomorrow.
Bad78Cutlass
Post by Bad78Cutlass » Sun Oct 19, 2014 2:05 am
Got the carb together and fired up yesterday. I had to grind the sides of the boosters to make them work in the body, which I expected. Alot of work went into it, first time I was that far involved into one of my own carbs...It's very responsive off idle, going for a drive tomorrow!
Bad78Cutlass
Post by Bad78Cutlass » Sun Oct 26, 2014 7:04 pm
Went out with it Friday night, had a ongoing traction issue. So wasted 3 passes, then tightened the front shocks up...went a 10.46 - Advanced the timing from 34 to 38 (done a big jump to see if it was in the right direction) went a 10.40...replaced the .156 BLP jets with .160's and went a 10.32...ran out of jets and went from leaving at 3000 to 4300 and finally went a 10.30 @ 129 / 6.54 @ 105 and a still awful 1.49 60ft. I need to get better front shocks
Notchback
Post by Notchback » Mon Nov 03, 2014 10:09 am
Nice!
Bad78Cutlass
Post by Bad78Cutlass » Wed Nov 05, 2014 12:01 pm
Thanks alot!
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Fri Feb 06, 2015 6:35 pm
Good Work there!
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
1.40 60' / 4.05 330' / 6.32@111.25mph
justahoby
Location: Temporarily in Stephenville, Texas, USA from Thunder Bay, Canada
Post by justahoby » Sun Mar 01, 2015 12:18 am
That polish sure bling the heck out of it ... Nice
As I'm approaching 40,I still think I'm 20. What the hell is wrong with me?
