Welding with a stick [ arc ] welder
Heat/AC, electrical, lighting, flooring, design, construction, photos...
Geoff2
Post by Geoff2 » Sat Sep 15, 2018 5:57 am
I am an amateur, self taught welder.
I have found that when I use s/steel rods to weld mild steel, I get much cleaner looking welds & less slag inclusions.
Is the strength of the weld affected or any other danger to welding mild steel with s/s rods?
Thanks.
tresi
Re: Welding with a stick [ arc ] welder
Post by tresi » Sun Sep 16, 2018 2:42 am
Most of the high cost no spec super rods for joining unknown or dissimilar metals such as carbon steel to stainless steel are nothing more than 309 or 312 stainless rods. The only thing about wrong about joining mild steel together with 309 rod is the cost. You should be able to make a fine weld with low hydrogen such as 7018
mk e
Post by mk e » Sun Sep 16, 2018 9:07 am
I've found the welds more prone to crack. I used to use 309 when I can't get the tight torch close enough or parts aren't fitted well or wasn't all that clean. The 309 will weld great but cracking next to the weld happens even under ideal conditions, at least for me so I've gone back to using it as a last resort.
Mark
Mechanical Engineer
Geoff2
Post by Geoff2 » Mon Sep 17, 2018 5:39 am
mk e.
What sort of welding are you referring to: gas, stick, TIG/MIG?
mk e
Post by mk e » Mon Sep 17, 2018 9:10 am
Tig. I know the question was specific to stick but I can't imagine you'd get a better/stronger result from stick over tig.
Mark
Mechanical Engineer
tresi
Post by tresi » Mon Sep 17, 2018 9:58 pm
If that weld area were to crack I would expect it to crack beside the weld due to weld is more ductile than the base metal. Not that I approve of this repair and I'm sure OSHA blow a gasket but I forced to weld a broken forklift mast back together. I used 309 and it never cracked. I applied a mild preheat and made sure it cooled to 200'ish degrees between passes.
exhaustgases
Post by exhaustgases » Tue Dec 11, 2018 9:56 pm
If you are using E7018 electrode and its cracking then your rod is probably moist or the base material is very cold and if your not keeping the electrode in the weld enough for the flux to keep out the air you introduce porosity. When flux on the rod is moist you can get hydrogen cracking. Someone mentioned TIG, on some of the items I have welded in the past there is no way that TIG would have worked. How much trouble would it be to weld 4 inch thick steel plate, Vee cut on both sides as a weld prep, it takes many multiple passes and that is using 1/4" diameter rod.
Keith Morganstein
Post by Keith Morganstein » Wed Dec 12, 2018 7:46 pm
The popular rods for mild steel are 6013, 7018 and 7024. You should be able to get good crack free welds with those.
7018 is the most popular structural welding rod that will run in any position. Keep the rods warm and dry.
7024 is excellent for flat (horizontal) and horizontal fillet welding. Very easy to weld with. It makes a great looking weld and the slag falls right off. 7024 runs fast, often called “jet rod” because it’s fast. Also called “monkey rod” because it’s so easy a monkey could weld with it.
6013 is popular for lighter work and also easy to weld with.
