Got a 1 off shaft I need made it's about 1.6"OD x7" long overall. I have drawing and cad model. Needs to have some journals ground and polished similar to crankshaft but there are no offsets involved.
If a anyone can help out or knows someone let me know.
Cheers
Wanted someone to make shaft with CNC
Re: Wanted someone to make shaft with CNC
Are there machine shops local to you? Almost all have CNC machines,( some don’t have any manual machines). If they have an OD grinder, they can finish it, otherwise the local crank grinder can. I’m sure Mike Jones of Jones Cams can, and others on the forum, but unless you’re in a remote area, it shouldn’t be hard to get made locally.digger wrote: ↑Sat Mar 24, 2018 1:22 amGot a 1 off shaft I need made it's about 1.6"OD x7" long overall. I have drawing and cad model. Needs to have some journals ground and polished similar to crankshaft but there are no offsets involved.
Cheers
I’m not sure how many views you get on this page, might post on general and shop tech too.
Automotive Machining, cylinder head rebuilding, engine building. Old school shop, semi-retired moonlighter. Can't seem to quit
