AutoSim Engine Simulator III
rayhall
Post by rayhall » Wed Sep 19, 2018 5:45 pm
I have developed a new engine simulator. The simulator lets you test and setup engine management ECU on the bench. Also can be used for ECU development.
This PDF file provides more information. http://www.turbofast.com.au/AutoSim/Doc ... torIII.pdf
Ray.
In-Tech
Re: AutoSim Engine Simulator III
Post by In-Tech » Thu Sep 20, 2018 11:59 pm
Hi Ray,
You show two LS patterns so I assume it does both the encoded LS1 24x as well as the 60-2 LS2/3, can you confirm? Also, does it do the accompanying cam signal as well? (1x cam for 24x and 4x cam for 58x) and is it synced to the crank signal so ecu doesn't error the cam/crank correlation?
Thank You
-Carl
rayhall
Post by rayhall » Sat Sep 22, 2018 2:40 am
Wayne,
I had renamed the two LS patterns in the actual software, just not in the PDF.
LSx 24 tooth.
All three signals are generated. Crank Signal A and B and the camshaft signal.
LSx 60-2
Generates crank 60-2 and cam signal.
Ray.
