Excellent shape. All software and hardware for bench included. No tooling. Uses any std flow bench fixtures. Will need 100AMP circuit for power.
$4500
Flow Data 700....
Flow Data 700....
Chris Straub
Performance Mfg.
http://www.straubtechnologies.com
www.distributorgears.com
Performance Mfg.
Re: Flow Data 700....
Are you replacing this bench with a different brand?
If so, which one?
Thanks.
If so, which one?
Thanks.
No I bought the bench thinking we would use it on heads that the SF600 would not handle. To use it 1 time a year is not worth it. So its forsale.
Chris Straub
Performance Mfg.
Performance Mfg.
(((((((((((( SOLD)))))))))))))))))))))
Chris Straub
Performance Mfg.
Performance Mfg.
