For Sale:
Comec CBN/PCD Resurfacer Auto I-1000
Like new condition.
I purchased this machine new (1 man shop) and have surfaced less than 500 cylinder heads with this machine. Works perfectly, I am selling because I am no longer doing cylinder head work.
Comes with 2 tool holders ( 1 for CBN and 1 for PCD) Also has "dummy" weight to make swapping from CBN to PCD a 60 second operation.
All original factory documentaion and instructions included.
Can be used to resurface heads, manifolds and block.
Variable table speed produces very smooth surfaces.
Looks new, works great. Machine located in NJ
Runs on 3 phase 220, but I used a 10HP phase convertor (Also available)
New machine cost over $24,000.
I am asking $15,000 w/convertor.
Email for more info.
email: Gesslerheadporting@msn.com
QuadraJetParts.com
http://www.quadrajetparts.com
Rochester, Carter/Edelbrock, Holley, Ford/Motorcraft, Stromberg Carburetor Parts
Re: Comec CBN/PCD Resurfacer Auto I-1000
Photos of machine and tooling are located here:
http://s279.photobucket.com/user/porter908/library/
Machine purchased in 2006. Machine is currently hooked up, you can see it run.
Convertor is 7.5 HP 30 Amp
I have 3 tool holders:
1 for CBN
1 for PCD
1 for Carbide
plus "dummy' holder
Also have additional shields not shown in photos. machine comes with everything that I originally got when new, even owners manual.
1 for CBN
1 for PCD
1 for Carbide
plus "dummy' holder
QuadraJetParts.com
16 great things about the Comec 1000 Resurfacer
1. Get a smooth, controlled finish every time. Electrically Driven Traversing Table with a variable speed table traverse and infinite speed control in each direction.
2. 24” between table and cutter plate. Roll over a 440 Chrysler block easily.
3. Power head traverse quickly positions head and eliminates operator fatigue.
4. Rigid cast iron base and table incorporate flat and v-way design for maximum accuracy and life.
5. Precision Vertical ball leadscrew increases sensitivity, accuracy, repeatability.
6. CBN milling, grinding or combination machines offer extreme versatility.
7. 14” Milling head with dual CBN Cutters.
8. Cast Iron “box” type columns with dovetail ways extend durability and precision.
9. High precision spindle bearings and heavy-duty precision construction allow operator to achieve
10. low RA surface finishes, and factory desired micro-inch finish with ease.
11. Ready to use with standard tooling of universal head and block fixturing, including cylinder head and block
12.Cylinder head mounting plate, universal rollover fixture and parallel supports
14. Variable speed spindle Infinite on the Fly
15. Ball Screw vertical feed
16. Joy stick Control Up Down and table Left and Right
Uses 1/2" CBN/PCD disc's
QuadraJetParts.com
Still Available
QuadraJetParts.com
Still available
call:
908-496-4188
call:
908-496-4188
QuadraJetParts.com
